New Vehicle Limited Warranty
General Motors Corporation will provide for repairs to the vehicle during the warranty period in accordance with the following terms, conditions, and limitations:
What Is Covered
Warranty Applies
This warranty is for GM vehicles registered and normally operated in Puerto Rico and U.S. Virgin Islands.
Repairs Covered
The warranty covers repairs to correct any vehicle defect related to material or workmanship occurring during the warranty period. Needed repairs will be performed using new or remanufactured parts. See Things You Should Know About the New Vehicle Limited Warranty for further details.
Warranty Period
The warranty period for all coverages begins on the date the vehicle is first delivered or put in use and ends at the expiration of the coverage period.
Bumper-to-Bumper Coverage
The complete vehicle is covered for 3 years or 36,000 miles, whichever comes first, for Chevrolet and Pontiac, and 4 years or 50,000 miles, whichever comes first, for Buick, Cadillac, and Saab, except for other coverages listed here under "What is Covered" and those items listed under "What Is Not Covered" later in this section.
Powertrain Coverage
The powertrain is covered for 5 years or 100,000 miles, whichever comes first, except for other coverages listed here under "What is Covered" and those items listed under "What is Not Covered" later in this section.
Engine: Cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, turbocharger, supercharger and all internal lubricated parts as well as manifolds, flywheel, water pump, harmonic balancer and engine mount. Timing belts are covered until the first scheduled maintenance interval.
Transmission/Transaxle/Transfer Case: Case, all internal lubricated parts, torque converter, transfer case, transmission/transaxle mounts, seals, and gaskets.
Drive Systems: Final drive housing, all internal lubricated parts, axle shafts and bearings, constant velocity joints, axle housing, propeller shafts, universal joints, wheel bearings, locking hubs, front differential actuator, supports, front and rear hub bearings, seals and gaskets.
Tire Coverage
The tires supplied with your vehicle are covered for defects in material or workmanship under the Bumper-to-Bumper coverage. Any tire replaced will continue to be covered for the remaining portion of the New Vehicle Limited Warranty.
Following expiration of the Bumper-to-Bumper coverage, tires may continue to be covered under the tire manufacturer's warranty. Review the tire manufacturer's warranty booklet or consult the tire manufacturer distributor for specific details.
Accessory Coverages
All GM accessories and parts sold by GM and permanently installed on a GM vehicle prior to delivery will be covered under the provisions of the New Vehicle Limited Warranty. In the event GM accessories are installed after vehicle delivery, or are replaced under the new vehicle warranty, they will be covered, parts and labor, for the balance of the vehicle warranty, but in no event less than 12 months/12,000 miles. This coverage is only effective for GM accessories permanently installed by a GM dealer or an associated GM-approved Accessory Distributor/Installer (ADI).
GM accessories sold over-the-counter, or those not requiring installation, will continue to receive the standard GM Dealer Parts Warranty of 12 months from the date of purchase, parts only.
GM Licensed Accessories are covered under the accessory-specific manufacturer's warranty and are not warranted by GM or its dealers.
Notice: This warranty excludes:Any communications device that becomes unusable or unable to function as intended due to unavailability of compatible wireless service from the wireless communication carrier that provides service for the OnStar® system.
Sheet Metal Coverage
Sheet metal panels are covered against corrosion and rust-through as follows:
Corrosion: Body sheet metal panels are covered against rust under the Bumper-to-Bumper coverage.
Rust-Through: Any body sheet metal panel that rusts through, an actual hole in the sheet metal, is covered for up to 6 years or 100,000 miles, whichever comes first; 6 years/unlimited miles for Buick, Cadillac, and Saab.
Important: Cosmetic or surface corrosion, resulting from stone chips or scratches in the paint, for example, is not included in sheet metal coverage.
Towing
Towing is covered to the nearest GM dealer if your vehicle cannot be driven because of a warranted defect.
No Charge
Warranty repairs, including towing, parts, and labor, will be made at no charge.
Obtaining Repairs
To obtain warranty repairs, take the vehicle to a GM dealer within the warranty period and request the needed repairs. A reasonable time must be allowed for the dealer to perform necessary repairs.
What Is Not Covered
Tire Damage or Wear
Normal tire wear or wear-out is not covered. Damage to the tire such as punctures, cuts, snags, and breaks resulting from pothole impact, curb impact, or from other objects is not covered.
Also, damage from improper inflation, high speed spinning, as when stuck in mud or snow, tire chains, racing, competition, improper mounting or demounting, misuse, negligence, alteration, or misapplication is not covered.
Damage Due to Accident, Misuse, or Alteration
Damage caused as the result of any of the following is not covered:
• Collision, fire, theft, freezing, vandalism, riot, explosion, or objects striking the vehicle.
• Misuse of the vehicle such as driving over curbs, overloading, racing, or other competition.
Proper vehicle use is discussed in the Owner Manual.
• Alteration or modification to the vehicle including the body, chassis, or components after final assembly by General Motors.
• Coverages do not apply if the odometer has been disconnected, its reading has been altered, or mileage cannot be determined.
Damage or Corrosion Due to Environment, Chemical Treatments, or Aftermarket Products
Damage caused by airborne fallout, salt from sea air, salt or other materials used to control road conditions, chemicals, tree sap, stones, hail, earthquake, water or flood, windstorm, lightning, the application of chemicals or sealants subsequent to manufacture, is not covered. See "Chemical Paint Spotting" under Things You Should Know About the New Vehicle Limited Warranty for more details.
Damage Due to Contaminated or Poor Quality Fuel
Poor fuel quality or incorrect fuel may cause driveability problems such as hesitation, lack of power, stall, or no start. It may also render gauges inoperable or degrade functionality for components such as spark plugs, oxygen sensors, and the catalytic converter. Damage from poor fuel quality, water contamination, incorrect diesel fuel or gasoline may not be covered.
It is recommended that gasoline meet specifications which were developed by automobile manufacturers around the world and contained in the World-Wide Fuel Charter which is available from the Alliance of Automobile Manufacturers at www.autoalliance.org/fuel_charter.htm. Gasoline meeting these specifications could provide improved driveability and emission control system performance compared to other gasoline.
Damage Due to Insufficient or Improper Maintenance
Damage caused by failure to follow the recommended Maintenance Schedule intervals and/or failure to use or maintain fluids, fuel, lubricants, or refrigerants recommended in the Owner Manual is not covered.
Important: This warranty is void on vehicles currently or previously titled as salvaged, scrapped, junked, or totaled.
Maintenance
All vehicles require periodic maintenance. Maintenance services, such as those detailed in the Owner Manual or Maintenance publications are at the owner's expense. Vehicle lubrication, cleaning, or polishing as well as items requiring replacement or repair due to vehicle use, wear, or exposure are not covered. Items such as:
Items such as:
• Audio system cleaning
• Brake pads and linings
• Clutch linings
• Coolants and fluids
• Filters
• Keyless entry batteries *
• Limited slip rear axle service
• Tire rotation
• Wheel alignment/balance **
• Wiper inserts
are covered only when replacement or repair is the result of a defect in material or workmanship.
* Consumable battery covered up to 12 months only.
** Maintenance items after 7,500 miles.
Failure or damage of one component due to vehicle use, wear, exposure or lack of maintenance of another component is not covered.
Extra Expenses
Economic loss or extra expense is not covered.
Examples include:
• Inconvenience
• Lodging, meals, or other travel costs
• Loss of vehicle use
• Payment for loss of time or pay
• State or local taxes required on warranty repairs
• Storage
Other Terms: This warranty gives you specific legal rights and you may also have other rights.
General Motors does not authorize any person to create for it any other obligation or liability in connection with these vehicles. Any implied warranty of merchantability or fitness for a particular purpose applicable to this vehicle is limited in duration to the duration of this written warranty. Performance of repairs and needed adjustments is the exclusive remedy under this written warranty or any implied warranty. General Motors shall not be liable for incidental or consequential damages, such as, but not limited to, lost wages or vehicle rental expenses, resulting from breach of this written warranty or any implied warranty. *
* Some states do not allow limitations on how long an implied warranty will last or the exclusion or limitation of incidental or consequential damages, so the above limitations or exclusions may not apply to you.
