How not to finish a race
by teamzr1
09/06/10 11:11 AM
When a Wazer tries to burn rubber
by teamzr1
09/06/10 10:41 AM
New CTS-V Caddie video
by teamzr1
09/03/10 02:07 PM
Is StingRay coming back ?
by Gregory T. Lloyd, DVM
09/01/10 05:34 PM
C6Rs Finish Fourth and Fifth in Abbreviated Mosport
by teamzr1
08/29/10 06:24 PM
Corvette Racing Qualifies Fourth and Sixth for Mosport
by teamzr1
08/28/10 06:39 PM
Mosport at 50: Corvette Memories
by teamzr1
08/26/10 08:29 AM
Talk Show Host to be First Corvette Engine Builder
by teamzr1
08/25/10 08:26 AM
Corvette Racing Finishes Third and Fourth in Road America
by teamzr1
08/22/10 09:58 PM
Corvette Racing Qualifies One-Two in Road America
by teamzr1
08/21/10 05:50 PM
What's Up
by teamzr1
09/06/10 11:11 AM
Corvette Tire Vibration
by teamzr1
09/01/10 06:31 PM
Corvette Battery Charger Accessory
by teamzr1
09/01/10 06:29 PM
Service Bulletin Number: 08-07-30-021
by teamzr1
08/31/10 11:22 AM
by teamzr1
08/29/10 06:24 PM
Automatic Belt Tensioner for C5/C6 Better design
by teamzr1
09/06/10 05:44 PM
by teamzr1
09/01/10 06:29 PM
New GM dexos Engine Oil Specification
by teamzr1
09/01/10 06:27 PM
NEW Deluxe Small Block 350
by teamzr1
08/17/10 03:17 PM
Timing versus Octane
by teamzr1
08/15/10 12:25 PM
Forum Stats
648 Members
24 Forums
1899 Topics
Max Online: 66 @ 08/21/10 12:38 PM
September
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Top Posters
teamzr1 2830
barkingowl 200
tici 154
Brett Hunter 55
Gregory T. Lloyd, DVM 53
Topic Options
Rate This Topic
#3197 - 11/09/09 02:21 PM Tuning and testing of 2010 ZR1
Loc: America
This relates to a 2010 ZR1 that only has 1,500 miles on it and our custom tuning.
Top results images shows what the numbers looked like with a normal long cruise in traffic.
Then though not normal for the owner was going to a drag strip maintaining the stock tires he did a test running the 1/4 mile without using the new launch control function and then with it on by the low level setting.
NOTE: as seen the launch control run was done last and by then the engine/engine bay had heat soaked and launch was done the intake air was up over 130 degrees causing knock which PCM pulled WOT timing.
If you carefully look though you see the engine and drivetrain was much smoother off the line and if the air temps are lowered then using launch control would have had better 1/4 values.
_________________________
JR
#3198 - 11/09/09 02:23 PM Re: Tuning and testing of 2010 ZR1 [Re: teamzr1]
Loc: America
As seen with our OBD scanner
JR
#3199 - 11/09/09 02:29 PM Re: Tuning and testing of 2010 ZR1 [Re: teamzr1]
Jim Shearer Offline
Member
Loc: Blue Springs, MO (KC suburb)
JR,
When you say "Shifts cost about 1 second" are you suggesting that it took 1/2 second to shift from 1st to 2nd and 2nd to 3rd?
2010 Black ZR1
2007 Black Corvette Z06
2000 Torch Red Corvette Convertible
#3200 - 11/09/09 02:51 PM Re: Tuning and testing of 2010 ZR1 [Re: Jim Shearer]
Loc: America
Jim replay your scanner recording in chart mode.
switch to elapsed time for top scale and then you can set the cursor as shown below 1 second lost getting off the line,
then 1/2 second cost per gear shift
JR
#3201 - 11/09/09 03:25 PM Re: Tuning and testing of 2010 ZR1 [Re: teamzr1]
Loc: America
Here we see between the 2 runs where the last run at launch the air temp was 13 degrees hotter and it came with a cost of more knock that had higher peak of reducing timing over a longer period of time.
Dealing with this will prevent performance loss
Edited by teamzr1 (11/09/09 03:44 PM)
JR
Moderator:  teamzr1
Who's Online
1 registered (1 invisible), 17 Guests and 5 Spiders online.
Sam E's stock 2001 with A4 C5 custom tuned
by teamzr1
09/07/10 03:31 PM
End of summer water/meth test
by teamzr1
09/05/10 03:31 PM
by teamzr1
09/01/10 06:31 PM
Dave W 2007 with A6 Stock with our custom tune results
by teamzr1
09/01/10 03:22 PM
by teamzr1
08/31/10 11:22 AM
General Water leak Guide
by teamzr1
08/31/10 10:16 AM
C6 TSB for ragtop failure at speed
by teamzr1
08/31/10 09:13 AM
(Views)Popular Topics
Restoring our 74 coupe... 10659
Team ZR-1 X-Pipe project 5381
Fuel consumption after top engine cleaning 4621
Injectors offset voltage times not created equal 4220
Get Custom tuned or Become a remote tuning location 3349
Positive Crankcase Ventilation 2962
Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870 2833
Brake fluid cause of jammed clutch debunked 2765
1991 ZR-1 Corvette Burns to the ground 2369
Part numbers for LS3, LS7, LS9 clutch, flywheel, master, slave 2335
Test & Tune
Effects of using E10 Gasoline
by teamzr1
09/08/10 06:54 PM
by teamzr1
09/07/10 03:31 PM
by teamzr1
09/05/10 03:31 PM
by teamzr1
09/01/10 03:22 PM
Don's 2008 LS3 MN6 Stock Readings
by teamzr1
08/26/10 01:25 PM
Corvette History Gallery
Installing SLP Blackwing and Airbridge on C6 with our Icebox
Puke Green Supercharged Corvette Grand Sport
Using crap tuners gets you a blown engine
Old Corvettes with a bit of new
White 2007 Z06
