Joined: Dec 2000 Posts: 5,268teamzr1 Owner - Pays the bills
If your looking to run a LS7 for racing or older carb based vettes GM now has a intake for that
25534394
LS7 4-Barrel Intake Manifold GM Racing design for use on LS7 heads As-cast design requires no porting for maximum performance Includes mounting bolts and instructions Uses LS7 carb intake gasket set P/N 19172113 Machined for 4150-style carburetors and has 3/8' NPT vacuum boss Also available with injector bosses P/N 25534413
Note: LSX Ignition Controller P/N 19171130 is required for carbureted applications
Here is one for LS3/L92
25534401
L76/L92 4-Barrel Intake Manifold GM Racing design for use on 'as-cast' rectangle port Gen IV cylinder heads As-cast design requires no porting for maximum performance Includes mounting bolts and instructions Uses L92/LS3 carb intake gasket set P/N 19172114 Machined for 4150-style carburetors and has 3/8' NPT vacuum boss Also available with injector bosses P/N 25534416
Note: LSX Ignition Controller P/N 19171130 is required for carbureted applications.
This one is for LS1/6/2 engines
88958675
LS2 4-Barrel Intake Manifold ' Allows you to install a four-barrel carburetor on a LS series engine with cathedral ports (LS1, LS6, LS2) ' Cast aluminum open-plenum intake manifold accepts a 4150-style square-bore carburetor ' Uses LS2 carb intake gasket set P/N 19156564 ' Bosses for EFI injectors for custom applications ' Bolts and instructions supplied
