How not to finish a race
by teamzr1
09/06/10 11:11 AM
When a Wazer tries to burn rubber
by teamzr1
09/06/10 10:41 AM
New CTS-V Caddie video
by teamzr1
09/03/10 02:07 PM
Is StingRay coming back ?
by Gregory T. Lloyd, DVM
09/01/10 05:34 PM
C6Rs Finish Fourth and Fifth in Abbreviated Mosport
by teamzr1
08/29/10 06:24 PM
Corvette Racing Qualifies Fourth and Sixth for Mosport
by teamzr1
08/28/10 06:39 PM
Mosport at 50: Corvette Memories
by teamzr1
08/26/10 08:29 AM
Talk Show Host to be First Corvette Engine Builder
by teamzr1
08/25/10 08:26 AM
Corvette Racing Finishes Third and Fourth in Road America
by teamzr1
08/22/10 09:58 PM
Corvette Racing Qualifies One-Two in Road America
by teamzr1
08/21/10 05:50 PM
What's Up
by teamzr1
09/06/10 11:11 AM
Corvette Tire Vibration
by teamzr1
09/01/10 06:31 PM
Corvette Battery Charger Accessory
by teamzr1
09/01/10 06:29 PM
Service Bulletin Number: 08-07-30-021
by teamzr1
08/31/10 11:22 AM
by teamzr1
08/29/10 06:24 PM
Automatic Belt Tensioner for C5/C6 Better design
by teamzr1
09/06/10 05:44 PM
by teamzr1
09/01/10 06:29 PM
New GM dexos Engine Oil Specification
by teamzr1
09/01/10 06:27 PM
NEW Deluxe Small Block 350
by teamzr1
08/17/10 03:17 PM
Timing versus Octane
by teamzr1
08/15/10 12:25 PM
Forum Stats
648 Members
24 Forums
1899 Topics
Max Online: 66 @ 08/21/10 12:38 PM
September
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Top Posters
teamzr1 2828
barkingowl 200
tici 154
Brett Hunter 55
Gregory T. Lloyd, DVM 53
Topic Options
Rate This Topic
#2735 - 08/01/08 02:52 PM Analyzing engine oil after 4 years of water/methanol use
Loc: America
The goal of sending engine oil to a testlab was to see after 4 plus years of using water/methnol injection if there was any real difference since with the engine and the makeup of the Mobil-I oil.
In short there was no degrading of the oil or the compounds found in the oil that use of water/meth causing any damage to engine or oil.
_________________________
JR
#2737 - 08/02/08 02:24 PM Re: Analyzing engine oil after 4 years of water/methanol use [Re: teamzr1]
Brett Hunter Offline
Loc: Texas
Good info, thanks!
Arctic White C6 Z51 6 speed
#2738 - 08/02/08 03:55 PM Re: Analyzing engine oil after 4 years of water/methanol use [Re: Brett Hunter]
Loc: America
Lots of good info there as you notice one test was when engine had only 6,500 miles and newest test mileage was 27,600 miles thus about 21,000 miles had elapsed over 7 years with a ton of high RPM, 100 % engine loads bouncing off rev limiter
and by knowing the metals in engine gives us a good look inside as if any piston's ring land was broke, head or intake gasket leaking, no water or fuel found in sample, etc so for price of oil test of $22 tells us a lot about engine without having to get inside of the engine ourselves.
About 20 gallons of water, 20 gallons of methanol and maybe 5 gallons of WW fluid went through these cylinders with zero signs any of it got into the oil says the engine is sound.
JR
#3492 - 07/17/10 04:09 PM Re: Analyzing engine oil after 4 years of water/methanol use [Re: teamzr1]
Loc: America
Engine problems predicted with oil analysis.
Indicator-------- Acceptable Levels-------- Engine Problem What to Check
Code:
Silicon (Si) and
Aluminum (Al)	10 to 30 ppm	Dirt ingestion	Air intake system, oil filter plugging, oil filler cap and breather, valve covers, oil supply
Iron (Fe) 	100 to 200 ppm	Wear of cylinder liner, valve and gear train, oil pump, rust in system	Excessive oil consumption, abnormal engine noise,performance problems, oil pressure, abnormal operating temperatures, stuck/broken piston rings
Chromium (CR)	10 to 30 ppm	Piston ring wear	Excessive oil blow-by and oil consumption, oil degradation
Copper (CU)	10 to 50 ppm	Bearings and bushings wear, oil cooler passivating,radiator corrosion	Coolant in engine oil, abnormal noise when operating at near stall speed
Lead (Pb)*	40 to 100 ppm	Bearing corrosion	Extended oil change intervals
Copper (CU) and
Lead (Pb)*	10 to 50 ppm	Bearing lining wear	Oil pressure, abnormal engine noise, dirt being ingested in air intake, fuel dilution, extended oil drain intervals
Aluminum (Al)	10 to 30 ppm	Piston and piston thrust bearing wear	Blow-by gases, oil consumption, power loss, abnormal engine noise
Silver and
Tin	2 to 5 ppm
10 to 30 ppm	Wear of bearings	Excessive oil consumption, abnormal engine noise, loss in oil pressure
Viscosity Change	 	Lack of lubrication	Fuel dilution, blow-by gases, oil oxidation, carburetor choke, ignition timing, injectors, injector pump, oil pressure
Water/Anti-freeze	 	Coolant leak or condensation	Coolant supply, gasket sealed, hose connection, oil filler cap and breather
* Significant as wear metal, only for engines using unleaded and diesel fuel.
JR
Moderator:  teamzr1
Who's Online
0 registered (), 4 Guests and 5 Spiders online.
Sam E's stock 2001 with A4 C5 custom tuned
by teamzr1
03:31 PM
End of summer water/meth test
by teamzr1
09/05/10 03:31 PM
by teamzr1
09/01/10 06:31 PM
Dave W 2007 with A6 Stock with our custom tune results
by teamzr1
09/01/10 03:22 PM
by teamzr1
08/31/10 11:22 AM
General Water leak Guide
by teamzr1
08/31/10 10:16 AM
C6 TSB for ragtop failure at speed
by teamzr1
08/31/10 09:13 AM
(Views)Popular Topics
Restoring our 74 coupe... 10649
Team ZR-1 X-Pipe project 5374
Fuel consumption after top engine cleaning 4620
Injectors offset voltage times not created equal 4209
Get Custom tuned or Become a remote tuning location 3345
Positive Crankcase Ventilation 2955
Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870 2827
Brake fluid cause of jammed clutch debunked 2751
1991 ZR-1 Corvette Burns to the ground 2366
Part numbers for LS3, LS7, LS9 clutch, flywheel, master, slave 2331
Test & Tune
by teamzr1
03:31 PM
by teamzr1
09/05/10 03:31 PM
by teamzr1
09/01/10 03:22 PM
Don's 2008 LS3 MN6 Stock Readings
by teamzr1
08/26/10 01:25 PM
Effects of using E10 Gasoline
by teamzr1
08/26/10 08:01 AM
Corvette History Gallery
Installing SLP Blackwing and Airbridge on C6 with our Icebox
Puke Green Supercharged Corvette Grand Sport
Using crap tuners gets you a blown engine
Old Corvettes with a bit of new
White 2007 Z06
