How not to finish a race
by teamzr1
09/06/10 11:11 AM
When a Wazer tries to burn rubber
by teamzr1
09/06/10 10:41 AM
New CTS-V Caddie video
by teamzr1
09/03/10 02:07 PM
Is StingRay coming back ?
by Gregory T. Lloyd, DVM
09/01/10 05:34 PM
C6Rs Finish Fourth and Fifth in Abbreviated Mosport
by teamzr1
08/29/10 06:24 PM
Corvette Racing Qualifies Fourth and Sixth for Mosport
by teamzr1
08/28/10 06:39 PM
Mosport at 50: Corvette Memories
by teamzr1
08/26/10 08:29 AM
Talk Show Host to be First Corvette Engine Builder
by teamzr1
08/25/10 08:26 AM
Corvette Racing Finishes Third and Fourth in Road America
by teamzr1
08/22/10 09:58 PM
Corvette Racing Qualifies One-Two in Road America
by teamzr1
08/21/10 05:50 PM
What's Up
by teamzr1
09/06/10 11:11 AM
Corvette Tire Vibration
by teamzr1
09/01/10 06:31 PM
Corvette Battery Charger Accessory
by teamzr1
09/01/10 06:29 PM
Service Bulletin Number: 08-07-30-021
by teamzr1
08/31/10 11:22 AM
by teamzr1
08/29/10 06:24 PM
Automatic Belt Tensioner for C5/C6 Better design
by teamzr1
09/06/10 05:44 PM
by teamzr1
09/01/10 06:29 PM
New GM dexos Engine Oil Specification
by teamzr1
09/01/10 06:27 PM
NEW Deluxe Small Block 350
by teamzr1
08/17/10 03:17 PM
Timing versus Octane
by teamzr1
08/15/10 12:25 PM
Forum Stats
648 Members
24 Forums
1899 Topics
Max Online: 66 @ 08/21/10 12:38 PM
September
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Top Posters
teamzr1 2828
barkingowl 200
tici 154
Brett Hunter 55
Gregory T. Lloyd, DVM 53
Topic Options
Rate This Topic
#3501 - 07/29/10 11:28 AM Stan S 2004 A4 with E10 gas issues
Loc: America
This 2004 with A4 trannie has a problem due again to use of Ethanol gas causing huge lean conditions. This is even worse on the day we were test and tuning in about 90 degree weather.
Being his 2004 is about stock like Dave M's ( review his results being tuned within 1 day of Stan's) and you see how much less performance there was due to higher then 10% ethanol gas being used.
This was peaking fuel trims as much as 25% lean with a average part throttle fuel trims of 12% lean !
_________________________
JR
#3503 - 07/30/10 09:40 AM Re: Stan S 2004 A4 with E10 gas issues [Re: teamzr1]
Loc: America
We had Stan find a gas station that sold normal gas with no Ethanol in it after getting the tank with ethanol used up
Here is a compare of with the Ethanol( on left) and then normal gas without making any changes to the tune
You see fuel trims went richer, HP and torque came up nicely.
I then tweaked the tune to fit using normal gas for best performance
As lean as ethanol makes engine, add 90 degree weather and it kills off performance in a big way
JR
Moderator:  teamzr1
Who's Online
1 registered (1 invisible), 11 Guests and 5 Spiders online.
Sam E's stock 2001 with A4 C5 custom tuned
by teamzr1
03:31 PM
End of summer water/meth test
by teamzr1
09/05/10 03:31 PM
by teamzr1
09/01/10 06:31 PM
Dave W 2007 with A6 Stock with our custom tune results
by teamzr1
09/01/10 03:22 PM
by teamzr1
08/31/10 11:22 AM
General Water leak Guide
by teamzr1
08/31/10 10:16 AM
C6 TSB for ragtop failure at speed
by teamzr1
08/31/10 09:13 AM
(Views)Popular Topics
Restoring our 74 coupe... 10649
Team ZR-1 X-Pipe project 5374
Fuel consumption after top engine cleaning 4620
Injectors offset voltage times not created equal 4209
Get Custom tuned or Become a remote tuning location 3345
Positive Crankcase Ventilation 2955
Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870 2827
Brake fluid cause of jammed clutch debunked 2751
1991 ZR-1 Corvette Burns to the ground 2366
Part numbers for LS3, LS7, LS9 clutch, flywheel, master, slave 2331
Test & Tune
by teamzr1
03:31 PM
by teamzr1
09/05/10 03:31 PM
by teamzr1
09/01/10 03:22 PM
Don's 2008 LS3 MN6 Stock Readings
by teamzr1
08/26/10 01:25 PM
Effects of using E10 Gasoline
by teamzr1
08/26/10 08:01 AM
Corvette History Gallery
Installing SLP Blackwing and Airbridge on C6 with our Icebox
Puke Green Supercharged Corvette Grand Sport
Using crap tuners gets you a blown engine
Old Corvettes with a bit of new
White 2007 Z06
