V8 Engine Fuel Injectors
There have been several cases of V8 engines with the wrong injectors installed.
The EPC may be unclear on which injectors to order. To avoid ordering incorrect parts, find the OEM number on the original injector.
Please see Bulletin #20-NA-098: Information on Fuel Injector Replacement Guidelines During Service, Malfunction Indicator Lamp (MIL) Illuminated for additional information on fuel injectors
M1L Corvette Transmission
Brand Quality would like to remind dealers that oil leak dye is not compatible with the M1L Corvette transmission and should not be used in place of trace powder. Document ID: 5395398 states:
“Caution: This transmission must use trace leak powder for fluid leak diagnosis.
Failure to use the recommended trace leak powder may cause internal transmission component damage
C8 Corvette (2020+) Instrument Cluster Programming
Dealers may have difficultly to program the Instrument Panel Cluster (IPC) in these vehicles.
This may be the result of completing Service Update N202314260, or it may be just a regular programming procedure for another issue.
If there is a concern where the Graphics Programming portion of the IPC will not complete, please make sure that there are not any communication issues or DTCs set that would apply to a different diagnostic path.
Also make sure that the ignition is in the OFF power mode and that an MDI 2 is being used for programming. In addition, verify the battery SOC is sufficient for programming.
If the programming procedure still will not complete, please contact Techline for additional programming support
Bulletin #22-NA-127: Radio Software Version V160 Update
This bulletin has been released for the 2021-2022 Camaro and Corvette to address a number of infotainment concerns.
Bulletin #22-NA-131:
Accessory Lighted Sill Plate Does Not Illuminate or Intermittently Illuminates
This bulletin has been released for the 2020 and 2021 C8 Corvette and others with the battery-powered illuminated sill plates. The kits have been discontinued.
If there is an issue with the sill plates that cannot be resolved with door fitment/activation tape positioning or battery
replacement, the customer should be given a refund for the cost of the sill plates
Bulletin #22-NA-132: Information on Service Front Lift System Message on Driver Information Center
(DIC), Fluid Leaking from Shocks - DTC C103E and/or C103C Set
This bulletin has been released for the C8 Corvette for a Front Lift System (RPO E60) issue that specifically calls out damage that have been caused to the front shocks by removing them and installing a lowering kit on the car.
It has been determined that the front shocks/actuators have been damaged by installing these various lowering kits, even if the car has been returned to stock height by removing the spacers
