#88 - 01/30/01 07:05 AM Windshield washer
ok i'm sure more than a few out there have or have had this problem as i've had it on several other cars myself, just never bothered to fix it before. my washer fluid doesn't spray. the resivior is full and i don't seem to have any blocked tubing. Are these pumps known to fail pretty regularly? Can they be rebuilt?
Clarence 92 Blk/Red Coupe
#89 - 02/02/01 09:36 AM Re: Windshield washer
I would think you first want to see if the system is just not really clogged up.
If not the pumps should be cheap, you might even find one in junk yard for just a few bucks.
#4257 - 12/30/18 03:10 PM Re: Windshield washer [Re: Anonymous]
C4 Grizz Bear Offline
Member
Member
Pueblo Colorado
Im with teamzr1....personally I had trouble with the squirters clogging, new blue juice these days can leave a residue too that actually clogs up the squirters. Then there's different "formulas" around the country that are really little more than water with blue coloring. Rated to 32 degrees is all, no biggie right? Dont buy the cheap stuff or if you do mix a little spic and span in it, (yes the dollar store stuff) takes care of bugs quicker and keeps lines from clogging.
1 registered members (teamzr1), 14 guests, and 6 spiders.
