#128 - 03/02/04 06:53 AM C5 cam specs
Here is the specs of the different C5 model years and LS1/LS6 stock cams
LS1 Lift Duration LSA Timing
97-99 .479/.472 207/199 117 113/121
2000 .500/.500 209/198 115.5 112/119
01-03 .479/.467 207/196 116 117/115
LS6
2001 .535/.525 211/204 116 114/118
02-03 .551/.555 218/204 117.5 115/120
Those with a LS1 then can see what they get with going with
a LS6 cam, keep in mind the stock LS6 heads flow about 10 cc more the
LS1 stock heads.
I would not go less then a 114 LSA for most street/track engines if
going with a 3rd party grind for any lower LSA will effect idle quality since smaller LSA creates less idle vaccum.
#129 - 12/08/04 11:21 AM Re: C5 cam specs
How would longer durations affect the idle vaccum. Say the common upper 220ish to lower 230ish range on a 115 LSA?
#130 - 12/08/04 11:52 AM Re: C5 cam specs
check the LSA thread
LSA
#131 - 12/09/04 11:44 PM Re: C5 cam specs
dmurf Offline
Pro
dmurf  Offline
Pro
Ashburn, Va
I read that the Z06 cam has smaller lobe diameter is there need to compensate for that in the LS1 if you do a cam swap to a Z06?
Longer Push rods or Z06 heads?
Are the vlaves in the 6 ltr truck heads the same length as the Z06. I read they share ports and valve diameter with the truck heads having larger combustio champers.
I was thinking about a Z06 Cam and LS2 truck heads for my LS1 when a Install the Magna Charger.
Better breathing, lower compression etc.
confused
DMurf
White Fang IV
Save the Wave!
