#152 - 12/05/04 01:45 PM Euro Headlamp Conversion
dmurf Offline
Pro
dmurf  Offline
Pro
Ashburn, Va
I recently updated my headlamps to the Factory Euro lamps, 100 Watt bulbs and 12 gauge wiring.
My night vision is like 10 times improved in highbeam and at least 8 times improved in lowbeams. Last year I was hit by a deer and this has been a nagging issue for drivablity for me scine I bought the car. Anyone interested in hearign what is required or how to perform this upgrade let me know. I will chronicle the process for you here.
DMurf
White Fang IV
Save the Wave!
#153 - 12/05/04 04:26 PM Re: Euro Headlamp Conversion
I have Euros too but I went a step further & added HIDs. Now I have extremely crisp white lows but no highs. frown
Do you know where I can get a good high/low H4 kit. I'm presently running Phillips ballasts.
#154 - 12/07/04 02:58 PM Re: Euro Headlamp Conversion
dmurf Offline
Pro
dmurf  Offline
Pro
Ashburn, Va
Dan Stern helped me with my conversion for Wiring Relays and bulb adaptors:
http://www.danielsternlighting.com/
Check it out.
DMurf
White Fang IV
Save the Wave!
#155 - 03/07/05 10:41 PM Re: Euro Headlamp Conversion
I bought LAPD's and it worked fine after shaun swapped out the first set of plug and play adapters. The first ones had too small of wires and melted the plugs.
#156 - 03/20/05 03:54 PM Re: Euro Headlamp Conversion
Just installed a set of the new redesigned Ajure LED tail lights. Truely a plug and play set up.
The old style, you had to dismantle some of the dash to get to the flasher unit and change it. The new design, accepts the OEM flasher, and is several times brighter than the first generation LEDS. The lenses themselves are quality units, far superior to the OEM units. And those suckers are Bright when you hit the brakes!! rock
#157 - 10/05/05 01:28 PM Re: Euro Headlamp Conversion
Speedway do you have any pics you can post?
