Topics3,614
Posts6,712
Most Online265 Jan 21st, 2023
#1007 - 08/31/05 07:47 AM
A4 - M6 transmission swap, how to reprogram?
I'm considering a transmission swap from A4 to M6. Mechanical + cabling all clear. Is there a way to reprogram the PCM using LS1Edit so that it thinks it's a M6? Or will I have to bring it to a GM agency for a reflash?
#1009 - 08/31/05 11:13 AM
Re: A4 - M6 transmission swap, how to reprogram?
In a first time I wanted to keep the A4 program and turn OFF the DTC's. But I don't know what kind of problems are related to this patched-up configuration.
Some kind of limp mode? Lower timing? Open loop? Richer AFR? ....
My actual VIN is 2G2FV32G9W2220630
2 (Country = Canada) G (Manufacturer = General Motors) 2 (Make = Pontiac) F (Carline Code = F-Body) V (Pontiac = Formula, Trans Am) 3 (Body Type = 2 door convertible) 2 (Restraint System = Manual Belt) G (Engine Code = 5.7L (V8) MFI) 9 (VIN verification) W( Model Year = 1998) 2 ( Assembly plant = St. Therese) 220630 = Production sequence
When you say "change 1 number in VIN so its seen a same car" you mean increase the production sequence by 1? (= 220631)
Thank you - Stefano
#1012 - 08/31/05 12:47 PM
All clear! But... wait a minute: my LS1Edit connector won't read it! I have only one licence I'll have to reuse the same number or buy another licence.
#1014 - 08/31/05 01:59 PM
OK I'll give it a try.
About the other question: if I keep the A4 program and turn off all the ralated DTC's will I have some kind of problem? I can copy the settings of another 98 program with an M6 in my standard program. Only the speedo doesn't work at it should.
Right now I don't know if turning off a DTC tells the PCM "ignore it" or "try to work around it without giving a trouble signal". Hard to explain... I can imagine that the PCM still try to command trans pressure, solenoids and so on: sees no results and try to solve a problem. Will it loose calculation capacity and become slow?
#1016 - 08/31/05 08:32 PM
#1017 - 09/01/05 01:50 PM
Here an idea...
What causes the PCM to know something is bad with the transmission? Faulty solenoids faulty thermometer faulty pressure sensor ....
What if I connect dummies (resistors and / or solenoids) to the A4 wires? Will the PCM just "think" everything is fine because of the dummies and allow me to use the M6 troublefree?
OK this is a junkyard-mechanic idea, but why not?
#1019 - 09/01/05 10:52 PM
There is an helpful thread on another forum about modifying the electric system to make it work. In reality it's not a clen job because the next owner will have an hard time if he brings the car in a garage.
I asked Carputing about reprogramming: apparently it's possible to load a M6 program keeping the old VIN. I'll post more about that when I'll exactly know how (and if) it really works.
#1021 - 09/11/05 12:14 PM
Today I loaded the Carputing M6 program: it works! Several parameters are now typical of a manual car: idle speed, trans oil temperature totally wrong, no tranny pressure, no commanded pressure... Then I loaded the program back to the laptop: now it has my original VIN and the original calibration number! At the end I loaded the A4 program (yes, I still have the automatic tranny) and everything went back to normal.
I don't know if this can be done using every program of the same year, I just know that Carputing did some modification to the program to fit my PCM.
0 registered members (),
5
guests, and
7
spiders. |
Admin,
Global Mod,
