Topics3,614
Posts6,712
#1007 - 08/31/05 07:47 AM A4 - M6 transmission swap, how to reprogram?
I'm considering a transmission swap from A4 to M6.
Mechanical + cabling all clear.
Is there a way to reprogram the PCM using LS1Edit so that it thinks it's a M6?
Or will I have to bring it to a GM agency for a reflash?
#1008 - 08/31/05 10:24 AM Re: A4 - M6 transmission swap, how to reprogram?
Its possible going from A4 to MM6 to use LS1edit and simply turn off the DTCs related to A4, and tweak the tune and get away with it.
You would not be able to go from a MM6 to a A4 and do the same thing
BUT really the correct path is have someone who can do a GM flash, change 1 number in VIN so its seen a same car but with a MM6 and then flash the PCM with a TECH -II for that year/trannie.
Of course then you have to totally tune the new flash for your other mods but now things like the 1 to 4 cags, reverse lockout, how MM6 handles column lock and computes gear ratio is all functional with correct MM6 flash being used.
You will of course need a wiring loom that is for a MM6 rather then the A4 wiring it uses.
MM6 uses a clutch switch so you also need that functional.
#1009 - 08/31/05 11:13 AM Re: A4 - M6 transmission swap, how to reprogram?
In a first time I wanted to keep the A4 program and turn OFF the DTC's. But I don't know what kind of problems are related to this patched-up configuration.
Some kind of limp mode?
Lower timing?
Open loop?
Richer AFR?
My actual VIN is 2G2FV32G9W2220630
2 (Country = Canada)
G (Manufacturer = General Motors)
2 (Make = Pontiac)
F (Carline Code = F-Body)
V (Pontiac = Formula, Trans Am)
3 (Body Type = 2 door convertible)
2 (Restraint System = Manual Belt)
G (Engine Code = 5.7L (V8) MFI)
9 (VIN verification)
W( Model Year = 1998)
2 ( Assembly plant = St. Therese)
220630 = Production sequence
When you say "change 1 number in VIN so its seen a same car" you mean increase the production sequence by 1? (= 220631)
Thank you - Stefano
#1010 - 08/31/05 12:13 PM Re: A4 - M6 transmission swap, how to reprogram?
Look at your A4 and there is a VIN Derivative code, then look at the MM6 it also has a code
Replace the last digits with the ones from MM6 in VIN #
Code
Position
 Definition
 Character
 Description
1
 Model Year
 2
 2002
2-3
 Model
 Y
 Corvette
4
 Transmission Type
 D
 RPO M30, HYDRA-MATIC 4L60-E
5
 Calendar Year
 3
 2003
6-8
 Julian Date (or Day of the Year)
9
 Shift Build
#1011 - 08/31/05 12:32 PM Re: A4 - M6 transmission swap, how to reprogram?
This is a valid VIN for a 1998 with a MM6
2G1FP22GXW2129570
#1012 - 08/31/05 12:47 PM Re: A4 - M6 transmission swap, how to reprogram?
All clear! smile
But... wait a minute: my LS1Edit connector won't read it! I have only one licence nono
I'll have to reuse the same number or buy another licence.
#1013 - 08/31/05 01:24 PM Re: A4 - M6 transmission swap, how to reprogram?
To have a dealer or someone replace your A4 flash with a MM6 then the Tech - II MUST see a VIN # with a digit saying its a MM6 that is how the tool decides which flash to install.
A gamble but you could email those highway robbers at carputing and ask if they would modify your existing flash file so that is becomes a MM6 F body.
#1014 - 08/31/05 01:59 PM Re: A4 - M6 transmission swap, how to reprogram?
OK I'll give it a try.
About the other question: if I keep the A4 program and turn off all the ralated DTC's will I have some kind of problem? I can copy the settings of another 98 program with an M6 in my standard program. Only the speedo doesn't work at it should.
Right now I don't know if turning off a DTC tells the PCM "ignore it" or "try to work around it without giving a trouble signal".
Hard to explain... I can imagine that the PCM still try to command trans pressure, solenoids and so on: sees no results and try to solve a problem. Will it loose calculation capacity and become slow?
#1015 - 08/31/05 02:53 PM Re: A4 - M6 transmission swap, how to reprogram?
Turning DTCs off does not tell the PCM to ignore the functions, just not to trip the errors.
If you turn off all A4 DTCs and also the trannie A4 tests
the MM6 as to tuning requires little other then making the right changes to idle, timing and torque management.
Simply make your tuning changes then drive the car with a good PCM scanner and see if any other DTCs have to be turned off but a 1998 has fewer DTCs and functions then newer PCMs
#1016 - 08/31/05 08:32 PM Re: A4 - M6 transmission swap, how to reprogram?
Thank you!
0 registered members (), 10 guests, and 12 spiders.
