Engine Torque Specs Application Spec Accelerator Control Cable Bracket Bolts 89 lb in Air Conditioning Compressor Bolts 37 lb ft Air Conditioning Compressor Bracket Bolts 37 lb ft Air Conditioning Idler Pulley Bolt 37 lb ft Air Conditioning Tensioner Bolt 18 lb ft Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts 15 lb ft Camshaft Retainer Bolts 18 lb ft Camshaft Sensor Bolt 18 lb ft Camshaft Sprocket Bolts 26 lb ft Catalytic Converter Nut 18 lb ft Connecting Rod Bolts - First Design (First Pass) 15 lb ft Connecting Rod Bolts - First Design (Final Pass) 60 degrees Connecting Rod Bolts - Second Design (First Pass) 15 lb ft Connecting Rod Bolts - Second Design (Final Pass) 75 degrees Coolant Temperature Gauge Sensor 15 lb ft Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) 240 lb ft Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes) 37 lb ft Crankshaft Balancer Bolt (Final Pass) 140 degrees Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 15 lb ft Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees Crankshaft Bearing Cap Side Bolts 18 lb ft Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence) 15 lb ft Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence) 53 degrees Crankshaft Oil Deflector Nuts 18 lb ft Crankshaft Position Sensor Bolt 18 lb ft Cylinder Head Bolts (First Pass all M11 Bolts in Sequence) 22 lb ft Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence) 90 degrees Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head) 90 degrees Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence) 50 degrees Cylinder Head Bolts (M8 Inner Bolts in Sequence) 22 lb ft Cylinder Head Coolant Plug 15 lb ft Cylinder Head Core Hole Plug 15 lb ft Drive Belt Idler Pulley Bolt 37 lb ft Drive Belt Tensioner Bolts 37 lb ft Engine Block Coolant Drain Plugs 44 lb ft Engine Block Heater 30 lb ft Engine Block Oil Gallery Plugs 44 lb ft Engine Coolant Air Bleed Pipe Bolts and Studs 106 lb in Engine Crossmember Bolts (Large) 107 lb ft Engine Crossmember Bolts (Small) 92 lb ft Engine Flywheel Bolts (First Pass) 15 lb ft Engine Flywheel Bolts (Second Pass) 37 lb ft Engine Flywheel Bolts (Final Pass) 74 lb ft Engine Flywheel-to-Torque Converter Bolts 44 lb ft Engine Front Cover Bolts 18 lb ft Engine Mount Heat Shield Nuts 89 lb in Engine Mount Stud-to-Engine Block 37 lb ft Engine Mount Through Bolts 70 lb ft Engine Mount Through Bolt Nuts 59 lb ft Engine Mount-to-Engine Block Bolts 37 lb ft Engine Rear Cover Bolts 18 lb ft Engine Service Lift Bracket M10 Bolts 37 lb ft Engine Service Lift Bracket M8 Bolt 18 lb ft Engine Valley Cover Bolts 18 lb ft Engine Wire Harness Clip Bolt 37 lb ft Engine Wire Harness Ground Strap Bolt 37 lb ft Exhaust Gas Recirculation (EGR) Valve Bolts (First Pass) 89 lb in EGR Valve Bolts (Final Pass) 22 lb ft EGR Valve Pipe-to-Cylinder Head Bolts 37 lb ft EGR Valve Pipe-to-Exhaust Manifold Bolts 22 lb ft EGR Valve Pipe-to-Intake Manifold Bolt 89 lb in Exhaust Manifold Bolts (First Pass) 11 lb ft Exhaust Manifold Bolts (Final Pass) 18 lb ft Exhaust Manifold Heat Shield Bolts 80 lb in Exhaust Manifold Pipe Nuts 26 lb ft Front Shock-to-Engine Crossmember Bolts 48 lb ft Fuel Injection Fuel Rail Bolts 89 lb in Generator Bracket Bolts 37 lb ft Generator Rear Bracket-to-Engine Block Bolt 18 lb ft Generator Rear Bracket-to-Generator Bolt 18 lb ft Ground Strap Bolt (at Rear of Cylinder Head) 37 lb ft Ignition Coil-to-Bracket Bolts 106 lb in Ignition Coil Bracket-to-Valve Rocker Arm Cover Bolts 106 lb in Intake Manifold Bolts (First Pass in Sequence) 44 lb in Intake Manifold Bolts (Final Pass in Sequence) 89 lb in Knock Sensors 15 lb ft Oil Filter 22 lb ft Oil Filter Fitting 40 lb ft Oil Level Indicator Tube Bolt 18 lb ft Oil Level Sensor 115 lb in Oil Pan Baffle Bolts 106 lb in Oil Pan Closeout Cover Bolt (Left Side) 106 lb in Oil Pan Closeout Cover Bolt (Right Side) 106 lb in Oil Pan Cover Bolts 106 lb in Oil Pan Drain Plug 18 lb ft Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil Pan-to-Front Cover) 18 lb ft Oil Pan M6 Bolts (Oil Pan-to-Rear Cover) 106 lb in Oil Pressure Sensor 15 lb ft Oil Pump-to-Engine Block Bolts 18 lb ft Oil Pump Cover Bolts 106 lb in Oil Pump Relief Valve Plug 106 lb in Oil Pump Screen Nuts 18 lb ft Oil Pump Screen-to-Oil Pump Bolt 106 lb in Oxygen Sensor 31 lb ft Positive Crankcase Ventilation (PCV) System Strap Nut (at Right Front Vapor Vent Pipe Stud) 106 lb in Power Steering Pump Bolts 18 lb ft Power Steering Pump Bracket Bolts 18 lb ft Spark Plugs (Cylinder Heads-New) 15 lb ft Spark Plugs (all Subsequent Installations) 11 lb ft Throttle Body Bolts 106 lb in Transmission Housing Bolt 37 lb ft Valve Lifter Guide Bolts 106 lb in Valve Rocker Arm Bolts 22 lb ft Valve Rocker Arm Cover Bolts 106 lb in Water Inlet Housing Bolts 11 lb ft Water Pump Bolts (First Pass) 11 lb ft Water Pump Bolts (Final Pass) 22 lb ft Water Pump Cover Bolts 11 lb ft
4L60-E Transmission Torque Specs Application Spec Accumulator Cover to Case Bolt 6-10 lb ft Case Extension to Case Bolt 31-35 lb ft Case Extension to Case Bolt (4WD Shipping) 8.3-16.7 lb ft Converter Cover Bolt 89 lb in Converter Housing to Case Screw 48-55 lb ft Cooler Pipe Connector 26-30 lb ft Detent Spring to Valve Body Bolt 15-20 lb ft Floorshift Control Bolt 89 lb in Flywheel to Torque Converter Bolt 46 lb ft Forward Accumulator Cover to Valve Body Bolt 6-10 lb ft Heat Shield to Transmission Bolt 13 lb ft Line Pressure Plug 6-10 lb ft Manual Shaft to Inside Detent Lever Nut 20-25 lb ft Negative Battery Cable Bolt 11 lb ft Oil Level Indicator Bolt 35 lb ft Oil Pan to Transmission Case Bolt 97 lb in Oil Passage Cover to Case Bolt 6-10 lb ft Park Brake Bracket to Case Bolt 20-25 lb ft Park/Neutral Position Switch Screw 27 lb in Plate to Case Bolt (Shipping) 20-25 lb ft Plate to Converter Bolt (Shipping) 20-25 lb ft Plug Assembly, Automatic Transmission Oil Pan (C/K) 22.1-29.5 lb ft Plug Assembly, Automatic Transmission Oil Pan (Y) 20.7-23.6 lb ft Pressure Control Solenoid Bracket to Valve Body Bolt 6-10 lb ft Pump Assembly to Case Bolt 19-24 lb ft Pump Cover to Pump Body Bolt 15-20 lb ft Shift Cable Grommet Screw 15 lb in Shift Control Cable Attachment 15 lb ft Speed Sensor Retainer Bolt 7.7-10 lb ft Stud, Automatic Transmission Case Extension (Y-car) 13-16 lb ft TCC Solenoid Assembly to Case Bolt 6-10 lb ft Trans Mount to Transmission Bolt 18 lb ft Transmission Fluid Pressure Manual Valve Position Switch to Valve Body Bolt 6-10 lb ft Transmission Oil Cooler Pipe Fitting 26-30 lb ft Transmission Oil Pan to Case Bolt 7-10 lb ft Transmission to Engine Bolt 35 lb ft Valve Body to Case Bolt 6-10 lb ft
T-56 Transmission Torque Specs Application Spec Backup Lamp Switch 20 lb ft Clutch Actuator Cylinder Bolt 71 lb in Clutch Housing Bolt 37 lb ft Control Lever Handle Bolt 18 lb ft Gear Select/Skip Shift Solenoid 30 lb ft Reverse Lockout Assembly Bolt 13 lb ft Reverse Lockout Solenoid 30 lb ft Shift Control Bolt 13 lb ft Shift Control Closeout Boot Bolt 18 lb in Shift Control Knob 27 lb ft Transmission Bolt 37 lb ft Transmission Drain/Fill Plug 20 lb ft Transmission Mount Bolt 38 lb ft Transmission Mount Nut 77 lb ft Transmission Support Bolt 66 lb ft Vehicle Speed Sensor Bolt 89 lb in
Clutch Torque Specs Application Spec Brake Pedal Pivot Nut 40 lb ft Clutch Actuator Cylinder Bolt 71 lb in Clutch Pressure Plate Bolt (5-Speed) 15 lb ft + 45 degrees Clutch Pressure Plate Bolt (6-Speed) 52 lb ft Clutch Master Cylinder Nut 15 lb ft Transmission Bolt (5-Speed) 55 lb in Transmission Bolt (6-Speed) 37 lb ft
