DTC B0333 Outside Air Temperature Sensor Open
Circuit Description
The outside air temperature sensor is located in the RH front of the engine compartment, on the radiator support near the horn assembly. In this position, it is exposed to airflow before the air enters the radiator. This provides a sample of the outside (ambient) air temperature.
The sensor is a thermistor used to control the signal voltage at the HVAC Control Assembly. The HVAC Control Assembly supplies a reference voltage (about 5 volts) on CKT 735 to the sensor and measures the voltage drop in the circuit to obtain a temperature signal. This signal is an input that tells the HVAC control head how much cooling or heating will be required to deliver to the passenger compartment. It also affects the mode and blower motor speed.
Resistance of the sensor varies from 242,700 ohms at -40°C (-40°F) to 2488 ohms at 60°C (140°F). When the outside (ambient) air temperature is cold, the thermistor resistance is high; therefore, the HVAC Control Assembly will receive a high signal voltage input. If the air temperature is hot, the thermistor resistance is low, the HVAC control head will receive a low signal voltage input.
The outside temperature is displayed on the display panel of the HVAC Control Assembly. The displayed temperature value is derived from a series of calculations performed by a processor in the HVAC Control Assembly. The calculations performed by the HVAC Control Assembly will use coolant temperature, vehicle speed, and ignition ON/OFF time to limit how fast the temperature display will be increased if a difference exists between the outside temperature sensor reading and the last value calculated by the HVAC Control Assembly for the temperature display. These calculations are used to eliminate any heat soak variations which may occur around the outside temperature sensor particularly after the engine has been turned off. If the car has been turned off for over 3 hours and then is restarted, the temperature display is immediately reset to ambient temperature conditions. If the car has been restarted within a 3 hour period after shutdown, the temperature display will not immediately reset. The temperature display will update after the car is driven between 32 and 72 km/h (20 and 45 mph) for 90 seconds or above 72 km/h (45 mph) for 60 seconds. In either condition, the temperature display will then be allowed to increase at the rate of 1.3 degrees Fahrenheit per second. Update rates are quicker at higher speeds because the outside temperature sensor reaches ambient temperature faster. If vehicle speed is not available from the Class II data line, it will be assumed to be at 40 km/h (25 mph). Finally, if coolant temperature is within 40°C (104°F) from the outside temperature sensor reading, the temperature display will update immediately upon vehicle start up. If the above conditions are not met, then the outside temperature display will not be allowed to increase.
A condition may exist were the outside temperature sensor is reading a lower temperature then the last calculated value stored in the HVAC control head. In this condition, the temperature display will always be allowed to decrease at a rate of 1.3 degrees Fahrenheit per second. Heat soak conditions in the engine compartment will not exist and thus do not cause a false lower temperature reading by the outside temperature sensor.
If the outside temperature sensor is shorted or not connected, the system will always read 13°C (56°F) as a default.
With the ignition in the ON position, CKT 735 is checked continuously.
CKT 735 stays at 4.5 volts or higher.
The HVAC Control Assembly displays the outside temperature as 13°C (56°F).
The HVAC Control Assembly stores a DTC B0333 in memory.
Conditions for Clearing the DTC
Using the IPC clearing feature.
Using a scan tool.
A history DTC will clear after 50 consecutive ignition cycles if the conditions for the fault is no longer present.
Diagnostic Aids
If the DTC is a history or an intermittent. Try to perform the tests shown while "wiggling" wiring and connectors, this can often cause the malfunction to appear.
Visually inspect sensor connector and harness for damage, corrosion or water intrusion.
Check for adequate terminal tension, mis-routed harness, rubbed through wire insulation, and broken wire inside insulation.
The resistance value of the sensor must be close to the values given in the chart. If not the sensor is considered skewed and must be replaced.
Test Description
The number(s) below refer to the step number(s) on the diagnostic table.
Tests for the proper operation of the circuit in the high voltage range.
Tests for the proper operation of the circuit in the low voltage range. If the fuse in the jumper opens when you perform this test, the signal circuit is shorted to voltage.
Step
Action
Value(s)
Yes
No
1
Did you perform the HVAC (CJ2) Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check
2
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the Outside Air Temp Sensor parameter in the HVAC data list.
Does the scan tool indicate that the Outside Air Temp Sensor parameter is within the specified range?
0.1-4.9 Volts
Go to Diagnostic Aids
Go to Step 3
3
Turn OFF the ignition.
Disconnect the Outside Air Temp Sensor.
With a scan tool, observe the Outside Air Temp Sensor parameter.
Does the scan tool indicate that the Outside Air Temp Sensor parameter is greater than the specified value?
4.9 Volts
Go to Step 4
Go to Step 5
4
Connect a 3 amp fused jumper wire between the signal circuit of the Outside Air Temp Sensor and the ground circuit of the Outside Air Temp Sensor.
Does the scan tool indicate that the Outside Air Temp Sensor parameter is less than the specified value?
0.1 Volts
Go to Step 8
Go to Step 6
5
Test the signal circuit of the Outside Air Temp Sensor for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 12
Go to Step 9
6
Test the signal circuit of the Outside Air Temp Sensor for a short to voltage, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 7
7
Test the ground circuit of the Outside Air Temp Sensor for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 9
8
Inspect for poor connections at the harness connector of the Outside Air Temp Sensor. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 12
Go to Step 10
9
Inspect for poor connections at the harness connector of the HVAC Control Assembly. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 12
Go to Step 11
10
Replace the Ambient Air Temp Sensor. Refer to Ambient Temperature Sensor Replacement .
Did you complete the replacement?
Go to Step 12
11
Replace the HVAC Control Assembly. Refer to Control Assembly Replacement .
Go to Step 12
12
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
