Topics3,714
Posts6,903
#1095 - 03/04/04 02:13 PM INJECTOR TUNING
Ok, I have ordered the SVO 30# injectors and I'll install them soon as I get them. I was set to get Dyno Tuned, but I figured I'll do injectors first do it all at once. So I want to know is all this can be done this way rather than using MAFT? I think so but want to make sure. This stuff is all confusing for me and dont know what I'm lookin at when I see a trend as posted here for the injector install by anothere Teammate. By the way the T stat mod works fine just have to have fans reset. Thanks
#1096 - 03/07/04 03:10 AM Re: INJECTOR TUNING
Man this board is dead! Hello anyone out there??
Look at the post dates kinda long in the tooth.
#1097 - 03/08/04 02:28 PM Re: INJECTOR TUNING
Yes it is best to first install the new injectors then start engine,
let engine warm up to normal and let idle for a good 5 minutes so PCM can relearn idle using new injectors.
Then driver the car for about 1 hour so PCM will relearn and re-cal for injectors using different engine loads.
After that the PCM tune should be done for PCM will have by then averaged out for new injectors.
Dyno tune is a waste of time for your ONLY seeing the few conditions and fuel trims used on a dyno which is nowhere near real world driving where all engine conditions, shifting, A/C, etc are used and PCM is adjusting for all of them not just the 20 seconds on a dyno with no idle, shifting lifting of gas pedal etc.
Using a PCM scanner recording while doing the different driving conditions/loads and then using that recorded data will get you a much better overall tune then a dyno will and how I haved tuned close to 200 cars
#1098 - 03/08/04 02:29 PM Re: INJECTOR TUNING
Most teammates prefer to use our Team ZR-1 email system rather then the forum, thus I do not check it every day.
#1099 - 03/08/04 02:46 PM Re: INJECTOR TUNING
Got it!!!
#1100 - 03/26/04 09:21 AM Re: INJECTOR TUNING
I agree real world drive that thing, and if you budget allows pick up a wide band O2 system. Your tuning will never be easier
