Joined: Dec 2000 Posts: 6,061teamzr1 Owner - Pays the bills
G101 left front frame (with SP101) G102 right front frame (with SP100) G103 left front of engine G104 frame next to battery (with G108 & SP102) G105 left lower engine block, engine ground strap & wire G106 Battery negative pole G107 Left rear head G108 frame next to battery (with G104) G201 bottom of A-pillar, left (with SP201 & SP203) G202 bottom of A-pillar, rt, bolted at the bottom (with SP202) G205 inside door pillar driver seat (with G301) G301 inside door pillar passenger seat G302 inside door pillar driver seat (with G205) G401 left rear outer frame G402 right rear inner frame SP201 bottom of A-pillar, left (bolted with G201) SP202 bottom if A-pillar, rt (bolted to G202) SP203 bottom of A-pillar, left (taped to wire bundle, with G201 coming out of it)
G101: windshield washer fluid pump Windshield washer fluid level switch Brake fluid switch Headlamp door assembly, left
G102: cooling fan, right Cooling fan 3 relay 44 Horn assembly Underhood lamp Headlamp door assembly, right Headlamp door control module A/c compressor clutch A/c compressor clutch diode Secondary air injection pump
G103: Electronic brake control module (ebcm)
G104: battery negative pole
Splice pack SP102: Marker lamp, right front Marker lamp, left front Park/turn signal lamp, right front Park/turn signal lamp, left front Turn signal lamp, right front Turn signal lamp, left front
Splice pack SP208: Body control module (bcm) Instrument panel cluster (ipc) Data link connector (dlc) Inflatable restraint & diagnosis module Inflatable restraint ip module disable switch Park/neutral switch Remote control door lock receiver
G105: fuel pump relay 35 Engine oil level switch Heater O2 sensor, bank 1 sensor 1 Heater O2 sensor, bank 1 sensor 2 Heater O2 sensor, bank 2, sensor 1 Heater O2 sensor, bank 2, sensor 2
G106: battery negative pole Ignition relay 42 Powertrain control modules (pcm, 4 wires) Throttle actuator control module (tac) Mass airflow sensor (maf)
G107: ignition control modules 1-3-5-7 Ignition control modules 2-4-6-8
G108: Electronic brake control module (ebcm)
G201: Splice pack SP201: Data link connector (dlc) Air temperature actuator Instrument panel cluster (ipc) Traction/suspension control switch Driver door module (ddm) Door latch, driver Auxiliary power outlet Windshield wiper motor Steering column lock Footwell courtesy lamp, left Instrument panel cluster (ipc) Hazard switch Telescopic actuator switch Splice pack SP203: Remote CD changer Fuse block I/P Speaker, right door Speaker, left door Radio
G202: Splice pack SP202: Passenger door module (pdm) Door latch, passenger side Body control module (bcm) HVAC control module IP compartment lamp Footwell courtesy lamp, right Vanity mirror lamp, left Vanity mirror lamp, right Inside rearview mirror Bose relay 45 Ignition switch Blower motor relay c60 Blower motor control processor Hood ajar switch Cigar lighter A/t shift lock control solenoid
G205: seat belt switch, driver Seat control module (scm), driver Seat pump, driver Seat belt switch, driver Seat relay center, driver
G301: defogger grid
G302: Splice pack SP302: Seat relay center, passenger Seat pump, passenger Rear compartment courtesy lamp, right Rear compartment courtesy lamp, left Rear compartment lid latch Rear compartment lid latch, right Rear compartment lid latch, left Folding top lid latch Folding top release switch Fuel door lock actuator Radio power antenna
G401: Splice pack SP400: Fuel pump & sender assembly, left Fuel level sender, right Tail, stop, turn signal, rear left Tail, stop, turn signal, rear right Center high mounted stop lamp Backup lamp, right Backup lamp, left License lamp, right rear License lamp, left rear Marker lamp, left rear Marker lamp, right rear
G402 electronic suspension control module (esc)
Passenger Car Zoning All grounds, in-line connectors, pass-through grommets, and splices have identifying numbers that correspond to where they are located in the vehicle. The following table explains the numbering system.
Callout Numbers Zone Description
100-199 Engine compartment- All forward of the dash panel
Note: 001-099 are additional for the engine compartment - ONLY to be used if all 100-199 items are used
200-299 Within the instrument panel area
300-399 Passenger compartment - From the instrument panel to the rear wheelhouse
400-499 Luggage compartment - From the rear wheelhouse to the rear of the vehicle
500-599 Within the left front door
600-699 Within the right front door
700-799 Within the left rear door
800-899 Within the right rear door
900-999 Within the luggage compartment lid or hatch
