by teamzr1. 07/12/25 05:53 PM
by teamzr1. 07/12/25 03:17 PM
C8 Cop Cruiser is the Winner
by teamzr1. 07/12/25 08:51 AM
by teamzr1. 07/10/25 02:52 PM
by teamzr1. 07/09/25 04:07 PM
by teamzr1. 07/10/25 04:24 PM
Topics3,621
Posts6,730
#1115 - 11/13/01 03:47 PM Modify thermostat and save big bucks
If you wanted to run your engine a bit cooler, either to richen up the AFR or reduce engine knock due to heat, you went out and bought a custom thermostat at a cost of about $80 with shipping as I did not once but twice got ripped off by a vendor of Corvetteforum.
I did this to find a 178 custom stat only allowed a maximum of 163 at highway speeds when used with a race radiator !
I was upset at this cost and not getting what it was supposed to be so I began studying the thermostat design and with the experience and knowledge of teammate Gary S, I began testing a method of modifying the stock thermostat and found for less then few dollars I could make the stock thermosat adjustable.
Review the process at :
Save money and modify stock stat
Here is my style of cooking on the stove, testing each shims thickness to opening temp.
Thus for a few bucks you now can adjust your stock termostat at a lower opening temperature.
#1116 - 11/28/01 12:01 PM Re: Modify thermostat and save big bucks
John,
This is a good idea anf I saw something like it before as it makes a world of difference.
I have a write up from somewhere showing a similar idea and his results were astounding.
I will search for it.
George
#1117 - 08/10/05 11:39 AM Re: Modify thermostat and save big bucks
Here a little upgrade...
Adjustable Thermostat
Hope you like it!
Stefano
#1118 - 08/10/05 02:29 PM Re: Modify thermostat and save big bucks
Yes I considered that but my fear was if anyone is doing such a mod and not done just right it could leak later on and/or suck air into system
Using a shim does not take more then a 1/2 to do the swap and using different thickness shims would dicate when stat begins to open
Also the newer stats function differently ( starting around 2002 model years on C5) and may also require some of the main spring to be cut down.
1 registered members (teamzr1), 13 guests, and 19 spiders.
by teamzr1. 07/09/25 03:19 PM
by teamzr1. 07/08/25 10:07 AM
