Document ID# 1964882
2007 Chevrolet Corvette
Subject: Fuel Trim System Lean P0171 P0174 - keywords 7.0 decl deceleration DTC engine fuel LS7 MAF MIL o2 sensor SES speed trim #PIP4125 - (04/24/2007)
Models: 2007 Chevrolet Corvette Z06
Equipped with the 7.0L RPO code LS7
Condition/Concern:
A dealer may encounter a 2007 Z06 Corvette setting lean Diagnostic Trouble Codes P0171 and P0174.
Recommendation/Instructions:
Complete the current SI diagnostics for any trouble code or symptom found. If diagnostics are inconclusive and the fuel trims show a lean condition at either steady throttle or deceleration, continue with the information found in this PI.
The MAF readings could be skewed and inducing a lean condition. Monitor the MAF sensor operation and compare it to a like vehicle. Replace the MAF sensor with a known good sensor to see if lean condition is changed. If there is no change to the lean condition, do not attempt any more repairs.
Engineering is investigating 2007 Z06 Corvettes that are setting P0171 and P0174, if it occurs as described in this PI.
This PI will be updated when more information becomes available.
