FRONTS - GM10339944. Torque upper control arm bolts 48 ft lbs/65Nm. Lower shock mount 21 ft lbs/28Nm. Upper shock mount 19 ft lbs/26Nm.
REARS - GM10339945.
NOTE:
Everytime you replace the rear shocks, you MUST replace the lower pinch bolt and nuts.
(2) 14048990 bolt and (2) 10516383 nut. The revised torque is 107 ft lbs on the BOLT HEAD < NOT THE NUT.
