Subject: Brake Pedal Position sensor Programming - keywords BPP circuit indicator lamp light message park pedal red signal switch #PIC4111 - (06/23/2006)
Models: 2006 Corvette Z06 only
Condition/Concern:
A concern may occur when attempting to program the Brake Pedal Position (BPP) sensor where the Tech 2 displays "ERROR, DEVICE CONTROL NOT ALLOWED". This could occur if the BCM does not recognize the apply and release of the park brake as specified during the calibration procedure.
Recommendation/Instructions:
To verify park brake lamp operation, apply the park brake and be sure the red "Brake" indicator on the IPC has illuminated. Then release the park brake and be sure the red "Brake" indicator has turned off. If the lamp does not illuminate, the concern above may apply. Inspect the connection at the park brake switch or circuit 1134 for an open. Once the red "Brake" indicator functions correctly, the BPP calibration can be performed.
