Trannie fluid is related to C5
Automatic Transmission: DEXRON®-III Automatic Transmission Fluid, G-license
number
Engine Coolant: A 50/50 mixture of clean, drinkable water and use only GM
Goodwrench® DEX-COOL® or Havoline® DEX-COOL® (silicate-free) coolant.
Engine Coolant Supplemental Sealer Notice: DO NOT use cooling system seal tabs
(or similar compounds) unless otherwise instructed. The use of cooling system
seal tabs (or similar compounds) may restrict coolant flow through the passages
of the cooling system or the engine components. Restricted coolant flow may
cause engine overheating and/or damage to the cooling system or the engine
components/assembly.
Engine Oil: The engine requires a special oil meeting GM Specification 4718M. Oils
meeting this specification may be identified as synthetic, and should also be
identified with the American Petroleum Institute (API) Certified for Gasoline
Engines STARBURST symbol. However, not all Synthetic API oils with the
STARBURST symbol will meet this GM Specification. Look for and use ONLY an oil
that meets GM Specification 4718M. For information on the proper oil viscosity,
refer to Engine Oil Viscosity under Explanation of Scheduled Services .
Engine Oil (Export) In areas of the world other than North America, it may be
difficult to find oils that display the API STARBURST symbol and that are labeled
as meeting the GM4718M Specification. If you cannot find API STARBURST
displaying oils identified as meeting the GM4718M requirements, look for oils that
meet the API Service SJ and ACEA A3-96 requirements. For information on the
proper oil viscosity, refer to Engine Oil Quality and Viscosity (Export) under
Hinges, Hood, Hatch, and Side Doors: Multi-Purpose Lubricant, Superlube® (GM
P/N 12346241 or equivalent)
Hinges, Concealed Headlamp, and Fuel Door: Multi-Purpose Lubricant, Superlube®
(GM P/N 12346241 or equivalent)
Hinges, Console Door, and I/P Compartment Door: Multi-Purpose Lubricant,
Superlube® (GM P/N 12346241 or equivalent)
Hood Latch, Pivots, and Spring Anchor: Lubriplate® Lubricant Aerosol (GM P/N
12346293 or equivalent) or lubricant meeting the requirements of NLGI # 2,
Category LB or GC-LB
Hood Release Pawl: Lubriplate® Lubricant Aerosol (GM P/N 12346293 or
equivalent) or lubricant meeting the requirements of NLGI # 2, Category LB or
GC-LB
Hydraulic Brake System: Delco Supreme 11® Brake Fluid (GM P/N 12377967 or
equivalent DOT-3 Brake Fluid)
Hydraulic Clutch System: Hydraulic Clutch Fluid (GM P/N 12345347 or equivalent
DOT-3 Brake Fluid)
Key Lock Cylinders: Multi-Purpose Lubricant, Superlube® (GM P/N 12346241 or
equivalent)
Manual Transmission: DEXRON®-III Automatic Transmission Fluid, G-license
number
Power Steering System: GM Power Steering Fluid (GM P/N 1052884 (pint) or GM
P/N 1050017 (quart), or equivalent)
Rear Axle (Limited-Slip Differential): SAE 75W-90 Synthetic Axle Lubricant, (GM
P/N 12378261) or equivalent meeting GM Specification 9986115. With a complete
drain and refill add 118 ml (4 ounces) of Limited-Slip Differential Lubricant
Additive (GM P/N 1052358 or equivalent)
Weatherstrip Conditioning: Dielectric Silicone Grease (GM P/N 12345579 or
equivalent)
Windshield Washer Solvent: GM Optikleen® Washer Solvent (GM P/N 1051515 or
equivalent)
