Low Coolant Message On The DTC Z06 Corvette Only - keywords electrical hot indicator low leak message sensor tank temperature #PIC4347 - (12/11/2006)
Models: 2006-2007 Chevrolet Corvette Z06 only
Condition/Concern:
Some owners of Corvette Z06 models may comment of a "Low Coolant" message in the DIC.
Recommendation/Instructions:
Inspect the vehicles coolant level. If the level is within normal operating range and no leaks are found, disconnect both the positive and negative battery cable from the battery and touch together for several seconds. Reconnect the battery cables and evaluate. If the message has gone away, return the vehicle back to the customer. No further action is required.
If the battery disconnect does not resolve the issue, then follow the procedures below.
• Replace the HVAC Control Module with a new HVAC Control Module from SPO. Note: All service HVAC Control Modules come equipped with base model calibration. Z06 Corvette requires a different calibration. Proceed to next step below.
• Contact Techline Customer Support (TCSC). Request an archive file to properly program the HVAC Control Module with Corvette Z06 calibrations.
• Re-evaluate the customers concern.
