P0480
DTC P0480
Circuit Description
Battery positive voltage is supplied to the cool fen 1 relay from the cooling fan 1 fuse. The Powertrain Control Module (PCM) controls the cooling fan 1 relay by grounding the low speed cooling fan relay control circuit via an internal solid state device called a driver. The primary function of the driver is to supply the ground for the component being controlled. Each driver has a fault line, which is monitored by the PCM. When the PCM is commanding a component on, the voltage potential of the control circuit should be low (near 0 volts). When the PCM is commanding the control circuit to a component off, the voltage potential of the circuit should be high (near battery voltage). If the fault detection circuit senses a voltage other than what is expected, the DTC will set. The PCM will monitor the control circuit for the following:
- A short to ground
- A short to voltage
- An open circuit
- An open relay coil
- An internally shorted or excessively low resistance relay coil.
When the PCM detects any of the above conditions, the DTC will set and the affected driver will be disabled, Conditions for Running the DTC
- The ignition voltage is between 6 and 18 volts.
- The engine speed is greater than 400 RPM.
- An improper voltage level has been detected on the low speed cooling fan relay control circuit
- The above conditions are present for at least 5 seconds.
- The PCM will illuminate the Malfunction Indicator Lamp (MIL) during the second consecutive trip in which the diagnostic test has been run and failed .
- The PCM will store conditions, which were present when the DTC set as Freeze Frame and Failure Records data.
Conditions for Clearing the MIL/DTC
- The PCM will turn OFF the MIL during the third consecutive trip in which the diagnostic has been run and passed.
- The History DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
- The DTC can be cleared by using the scan tool.
Diagnostic Aids
Check for the following conditions:
- A faulty connection at the PCM, inspect the harness connectors for the following conditions.
-- Backed out terminals
-- Improper mating
-- Broken locks
-- Improperly formed or damaged terminals
-- Faulty terminal to wire connections
-- Inspect the wiring harness for damage.
- If the harness appears to be OK, disconnect the PCM, turn the ignition ON and observe a Digital Multimeter (DMM) connected between the low speed cooling fan relay control circuit of the cooling fan 1 relay and ground at the PCM harness connector. While moving connectors and the wiring harness related to the cooling fan 1 relay, a change in voltage will indicate the location of the fault.
Review the Freeze/Failure Records vehicle mileage since the diagnostic test last failed. This may help determine how often the condition that caused the DTC to be set occurs.
Test Description
1. Listen for an audible click when the cooling fan 1 relay operates. Command both the ON and OFF states. Repeat the commands as necessary.
2. Tests for voltage at the coil side of the cooling fan 1 relay. The cooling fan 1 fuse supplies battery positive voltage to the coil side of the cooling fan 1 relay.
3. Verifies that the PCM is providing ground to the cooling fan 1 relay.4.
4. Tests if ground is constantly being applied to the cooling fan I relay.
