Starting with '02 new cam grind and because of that the valves are 0.6 mm longer to compensate for changes to the camshaft base circle.
Also starting in '02 the heads were constructed differently then the older sand molded type to newer ones are semi-permament mold casting.
Claim is the newer heads are about 6-10 HP more over pre '02
