Originally posted by dmurf:
Had you considered a LS2 Iron Block. Yeah it is a truck motor but .060 bore nad 4 stroke and you got a 409 Cu In Chevy. You can get 11.3. to 1 or 9 to 1 for a huffer.
SLP makes it a 402 stoke bore short block for $3,500 and Several guys make the 409 Short, More sells it for like $8-9K
Its an idea! cool
Interesting idea. However, I currently just autocross the car, and occasionally drag. With the kind of driving I do, I'd hate to mess with the front/rear weight ratios. I'd imagine the iron block would add 1-200 lbs. That's significant! The other consideration is I run ASP in SCCA, which is basically a stock motor, but I can alter intake and exhaust. The reason for the Z06 heads and cam is they are production parts on a Corvette, thus adding them to my car still leaves me "technically" stock, but I get the added giddyap!!!
