Update almost a year later.
Vendor of Autotap finally releases V2 which they claimed would fix all ills of Verson 1.
Bottom line, V2 is worse then V1, still cannot maintain link to PCM for more then a few minutes on a C5, you cannot scan without recording, scaling of PIDs are not correct and being this was a tottaly new version should be many times better then the 1st version
At the same time they market against themselves by OEMing Efilive scanner and each scanner claims it is the best scanner around
