JR you might look into the Harness Bar made by Brey-Krause. I put one in my Z-06 and it was an excellent fit. I am able to use a 6 point harness with it. You can get the info at
www.bkauto.com. Everything is stainless steel and all of the mounting hardware is included. I am able to use the 2 point submarine belt and seat belts either attached or removable using clips on the ends instead of bolting it to the floor. I leave the sub belts attached and detach the seat belts at every event--takes two minutes. This way I am not climing all over seatbelts when I load and unload the trailer.
[B]Now that the rebel has been baselined, to make it race ready the changes I will do myself in next week or so are:
3. To start installing a AS&M 5 point harness bar and belts, later to be replaced with a rollcage.
