by teamzr1. 11/13/25 07:26 AM
Topics3,710
Posts6,899
#1274 - 07/11/02 05:00 PM Steve's 99 with SC dyno Results
I'll let Steve fill in all the details about his '99 C5 that he just put a ATI 7 PSI Supercharger in and his first dyno with it installed.
I met with him at a dyno shop that uses a Dynopack chassie dyno that they take the rear wheels off and bolt a chassie unit to each wheel.
In seeing this I am not found of that type of dyno. I believe the dyno results are a tad lower then the real performance numbers.
At this time what is needed to complete his project is larger injectors, finding out why boost only went to 6.39 lbs, I will compete the PCM calibration tuning and the IAT is a bit hot even after going through the intercooler.
These are results of combining 3 dyno runs.
#1275 - 07/12/02 08:34 AM Re: Steve's 99 with SC dyno Results
JR,
I realize that this is the first pull on the dyno but one thing really stands out to me. I have seen several other dyno charts of C5's with the ATI ProCharger and they all ran between 540 and 580 HP. This seems fairly low on HP.
#1276 - 07/12/02 02:34 PM Re: Steve's 99 with SC dyno Results
Jim,
keep in mind this LS1 is still fairly stock, stock cam, and the owner wants redline to be at 6,000 RPMs.
Looking at the raw PCM data the injectors as in your case were hitting 100 % dutcy cycle ( 22 ms pulse width) before even getting to that redline and the superchips tuning as you know is not very good for the SC.
Being the boost went to 6.39 max and your ATI is boosting a bit over 7 PSI we have to wait for the larger injectors and my tune to get the numbers better then it is out of the box.
#1277 - 07/13/02 06:54 AM Re: Steve's 99 with SC dyno Results
I went to the Speed Merchants today to have a baseline dyno for my car. First of all I was not sure what numbers the car would turn. I knew that the car pulled hard, spun the tires in first and second as well as bounced off the rev limiter without even trying hard.
When John and I arrived the tech drove my car in while I signed the paperwork. John was there to take Traces with the Ease Software for future tuning purposes. The fee for an hour of dyno time is $130. I asked the tech if he can run Boost numbers as well as hooking up a Fuel pressure gauge so I can look at the pressure while the car is under WOT. Built into the dyno's computer system was already a boost line that was hooked up in line with the blow off system that is now on the car.
After 3 runs here are the results:
Worst run:468 RWHP & 438 RWTQ
Best run: 471 RWHP & 443 RWTQ
Steve
#1278 - 07/19/02 12:43 PM Re: Steve's 99 with SC dyno Results
For those of you who are closely watching my progress rock My 42lb injectors will be here Monday and the LS1 Edit program is about 2 weeks away!! I am also having problems with the cooling system which I hope to have fixed before then. smile
Steve <img src="graemlins/cheers.gif" border="0" alt="[cheers]" />
#1279 - 07/21/02 11:23 AM Re: Steve's 99 with SC dyno Results
Steve if you want you can come by and we can put the new injectors in and then I can take your 38s and put them in mine to test them.
There should be no reason with that larger radiator to be having cooling problems.
#1280 - 07/22/02 09:39 AM Re: Steve's 99 with SC dyno Results
Seems that the ATI fan is not going into the high speeed setting. Since the fan runs all the time it does not let air through fast enough to cool at Freeway or low speed high rpm runs. I am looking into that problem now. Trying to come up with a good solution that will be the long term fix. I will keep you posted.
John, thanks for the offer. If I do the work here or there, you have those injectors to test out on your car. smile
Steve rock
#1281 - 07/22/02 09:52 AM Re: Steve's 99 with SC dyno Results
The fan control I can fix when we do the PCM calibration changes.
As I mentioned before you get your LS1edit you can come by and I can download your flash and we can see what everything is set to and I can do all the code changes and have a flash ready so when your LS1edit arrives all you need to do is upload the new changes to the PCM.
#1282 - 07/24/02 07:28 AM Re: Steve's 99 with SC dyno Results
#1283 - 07/24/02 07:55 AM Re: Steve's 99 with SC dyno Results
Steve maybe if I saw what they did I could make something up to correct the cooling problem.
Next time your at my place I can look at it and see what can be done.
