I read that the Z06 cam has smaller lobe diameter is there need to compensate for that in the LS1 if you do a cam swap to a Z06?
Longer Push rods or Z06 heads?
Are the vlaves in the 6 ltr truck heads the same length as the Z06. I read they share ports and valve diameter with the truck heads having larger combustio champers.
I was thinking about a Z06 Cam and LS2 truck heads for my LS1 when a Install the Magna Charger.
Better breathing, lower compression etc.
confused
DMurf
White Fang IV
Save the Wave!
