C8 Corvette Wins GT Asia Race
by teamzr1. 07/13/25 03:54 PM
by teamzr1. 07/13/25 01:45 PM
by teamzr1. 07/12/25 05:53 PM
C8 Cop Cruiser is the Winner
by teamzr1. 07/12/25 08:51 AM
by teamzr1. 07/10/25 02:52 PM
by teamzr1. 07/09/25 04:07 PM
by teamzr1. 07/10/25 04:24 PM
Topics3,622
Posts6,733
#1328 - 02/08/02 12:23 PM Info on purchasing EASE software/laptop requirements
I'm interested in purchasing the EASE scan software. What type of memory/accessory requirements are necessary on my laptop to be able to install and run the program?
I have a severe rich condition on my '02 Z06 after installing a Vortex Rammer airbox and I need to see what's going on and correct the problem (MAFT, custom PCM reflash, LS1edit-->assuming its coming out shortly for the '01-02).
Thank you,
#1329 - 02/08/02 03:40 PM Re: Info on purchasing EASE software/laptop requirements
Wes,
I would suggest any laptop that has at least a 200 Mhz cpu would be fine.
You can use ay version of MS windows, thus if you want little RAM then use windows 95 or 98.
I's say no less then 24 megs of RAM, mostly for windows use.
It does need a serial com port, 9 pin connect.
If it has only USB, then you also need to buy a USB to 9 pin com cable ( can be bought at Ease).
You need a floppy and C/D drive to install the software, after that you do not need the C/D.
Since most laptop P/C battery do not last long and your using a com port that uses more current, I'd suggest a cheapo D/C to A/C converter you plug into cig lighter. I got mine at radio shack for about $40. If staying with laptop battery make sure it is fully charged.
Ease has version also that work on pocket P/C and PDA but do not have the same level of features as the laptop does.
I can get you a 10% discount off of any Ease product, thus the G.M enhanced powertrain scanner Ease charges is $350 but through me is $315.
You can contact me and I will be happy to help you analyze yor PCM traces and let you know what I would do in tuning to get a good performnace tune.
John
Thank you,
#1330 - 02/26/02 06:15 AM Re: Info on purchasing EASE software/laptop requirements
I recently purchased the Ease scan tool and can tell you that is works like a charm. Running it on Windows xp with zero problems.
#1331 - 03/17/03 11:40 AM Re: Info on purchasing EASE software/laptop requirements
does ease have a website? anyone got a link?
i currently have atap... and am debating switching to ease....
thanks!
#1332 - 03/17/03 11:48 AM Re: Info on purchasing EASE software/laptop requirements
nevermind.... i quit being lazy and did a quick search laugh
http://www.obd2.com/
#1333 - 04/26/03 04:41 PM Re: Info on purchasing EASE software/laptop requirements
Hello Wes, this is Roger and Jeff over from the ************* .com. Thought I would say hello, as this is my first post on this forum. I was told about this forum after I put a post about my new BIG cam (228/234//607/.598/110 ls) I had installed a few weeks ago. I am now wanting to get it tuned as it is a little out of mine and Jeff's expertise with our knowledge of LS1 Edit so far. I am sure Jeff could tune it, but he has such limited time because of his job.
We have had EASE about a year and it is fairly easy to use. I am still figuring out where things are on it, but our problem has primarily been the lack of time using it.
I came over to this forum hoping to get ideas on how to tune this cam. I expected a rough idle and so far it has not disappointed me! But our hp increased 56 hp with just the stock tune. However, it is running real rich and that is what we need to tackle next.
0 registered members (), 15 guests, and 10 spiders.
by teamzr1. 07/09/25 03:19 PM
by teamzr1. 07/08/25 10:07 AM
