Bulletins for 1997 Chevrolet Corvette V8-350 5.7L VIN G SFI
Safety Recalls
TSB Number Issue Date TSB Title
1. 97014 MAR 97 Rear Suspension Tie Rod Assembly May Fracture
Service Bulletins
1. 99-06-03-012 DEC 99 Battery Testing and Replacement
2. 99-00-89-021 DEC 99 December 1999 Labor Time Guide Updates
3. 99-01-38-006 DEC 99 J-43600 ACR2000 Refrigerant Recovery/Recharge Equipment
4. 99-00-89-022 DEC 99 The Year 2000 and Vehicle Electronics
5. 99-08-45-005 NOV 99 Accessory Receptacle/Cigar Lighter is Inoperative
6. 99-00-84-021 NOV 99 Expediting Parts
7. 99-00-89-020 NOV 99 November 1999 Labor Time Guide Updates
8. 99-08-46-001 NOV 99 OnStar(R) Kit Part Numbers and Compatibility
9. 99-06-04-053 NOV 99 Powertrain Control Module Reprogramming
10. 99-08-42-009 NOV 99 Setting of I/P Dimmer Control to View PRNDL Display
11. 99-01-39-007 OCT 99 Automatic Air Conditioning Control Operation
12. 99-03-10-103 OCT 99 Discontinue Usage of Tool J 6627-A
13. 99-06-02-016 OCT 99 Engine Low Coolant Light Comes On At Start-up
14. 99-07-30-021 OCT 99 New Solenoid Testing Kit For All Hydra-Matic Trans.
15. 99-00-89-017 OCT 99 October, 1999 Labor Time Guide Updates
16. 99-06-02-017 OCT 99 Radiator Repair/Replacement Guidelines
17. 99-08-51-007 OCT 99 Refinishing Aluminum Wheel
18. 99-08-52-005 OCT 99 Remote Keyless Entry Operational Characteristics
19. 99-00-89-019 OCT 99 Warranty Parts Center/Corporate Parts Return Program
20. 99-00-89-016 SEP 99 1994-2000 Labor Time Guide - Updates
21. 99-07-30-017 SEP 99 Auto/Trans Oil Cooler Flushing and Flow Check Procedures
22. 99-07-30-020 SEP 99 Automatic Transmission Service Procedure Change
23. 99-08-64-016 SEP 99 Use of Silicone for Weatherstrip Maintenance
24. 99-08-49-008 JUL 99 Chime Sounds When Key is Removed From Ignition
25. 000000A JUL 99 GM Service Bulletin Precautions
26. 99-00-89-010 JUL 99 July,1999 Labor Time Guide Updates
27. 99-08-50-010 JUL 99 Premature Wear of Leather on Bucket Seatback Bolster
28. 99-00-89-008 JUN 99 June 1999 Labor Time Guide Updates
29. 99-03-10-102 JUN 99 Original Equipment Chrome Plated Aluminum Wheel ID
30. 99-06-01-011 JUN 99 Second Design Connecting Rod Bolt and Torque Specs
31. 99-07-29-001 JUN 99 Squeak Type Noise from Shift Boot When Shifting
32. 99-06-01-007 MAY 99 Accessory Drive Squeak
33. 99-00-89-006 MAY 99 May 1999 Labor Time Guide Updates
34. 99-00-89-004 APR 99 1994-2000 Labor Time Guide Updates
35. 99-08-49-006 APR 99 Cleaning of Upper Instrument Panel Surfaces
36. 99-08-51-001 APR 99 Paint-less Dent Repair Process
37. 99-08-52-002 APR 99 Remote Keyless Entry/Low Tire Pressure Monitoring Inop
38. 99-06-01-004 APR 99 Revised Dimension for Engine Block Rear Oil Gallery Plug
39. 99-00-89-003 MAR 99 1994-2000 Labor Time Guide Updates
40. 99-06-03-002 MAR 99 Battery Insulator Replacement
41. 99-07-30-005 MAR 99 Component Slipping/DTC P1870 Diagnosis
42. 99-06-03-001 MAR 99 Essential Tool J 42000 Battery Tester
43. 99-06-04-013 MAR 99 New Chassis Fuel System Service Kits
44. 83-81-34 MAR 99 Operating Vehicle with SIR Warning Light On
45. 99-06-04-009 MAR 99 Revised Fuel Sender Replacement Procedures
46. 99-08-50-002 MAR 99 Revised Seatback Cover Removal Procedure
47. 99-00-89-002 MAR 99 Using the New GM Service Bulletins
48. 99-00-89-001 FEB 99 1994-99 Car and Truck Labor Time Guide Updates
49. 99-01-39-004 FEB 99 Air Conditioning Odor
50. 83-63-10A FEB 99 Fuel Pump Noise Coming from Pump or Fuel Tank Area
51. 99-06-02-008 FEB 99 Water Pump and Pulley Identification and Usage
52. 83-05-11 JAN 99 1994-99 Labor Time Guide Updates
53. 83-12-21 JAN 99 Contaminated R134a A/C Systems
54. 86-05-02 DEC 98 Delayed Warranty Start Process
55. 83-15-23 DEC 98 Information on Roof Panel Replacement
56. 83-05-10 DEC 98 Labor Guide Updates for 94/99 Cars and Trucks
57. 87-71-74 NOV 98 1-2 Accumulator Piston and Outer Spring Replacement
58. 83-35-08 NOV 98 Chemical Staining of Chrome Wheels
59. 83-05-09 NOV 98 Labor Time Guide Updates for 1994-99 Cars and Trucks
60. 83-01-20 NOV 98 Temporary Changes to Techline ESI Applications
61. 83-32-10 NOV 98 Tool J 43435 Adjuster Locknut Wrench
62. 83-32-09 NOV 98 Tool J 43485 Power Steering Bleeder Adapter
63. 83-17-04 OCT 98 Door Handles on White Painted Vehicles Turning Yellow
64. 83-83-15A OCT 98 Information on I/P Cluster Replacement and Diagnosis
65. 83-05-08 OCT 98 Labor Time Guide
66. 83-15-16 OCT 98 New Windshield and Glass Urethane Adhesive Caulking Kit
67. 76-02-02A OCT 98 Recommended Axle Lubricant
68. 83-81-32 SEP 98 Information On New PCM Connector Service Kits
69. 83-90-14 SEP 98 Inoperative RKE and/or TPM Systems
70. 83-05-07 SEP 98 Labor Time Updates
71. 83-02-01 SEP 98 Revised Crankcase Ventilation System Maintenance
72. 83-83-16 SEP 98 Speedometer Accuracy
73. 43-17-01B AUG 98 Bumps or Rust Colored Spots in Paint
74. 84-96-01 AUG 98 Correct Labor Code Usage for Entertainment Systems
75. 76-60-04A AUG 98 Engine Oil Consumption Guideline
76. 83-90-12 AUG 98 Keyless Entry Transmitter Tester
77. 83-05-06 AUG 98 Labor Time Updates
78. 87-61-29 AUG 98 Oil Pressure Testing Tool
79. 80-05-03 AUG 98 Redefined Use of Parts Warranty Special Claims B and C
80. 87-61-27 AUG 98 Revised Torque Specifications for Cylinder Head Bolts
81. 68-05-02B JUL 98 Courtesy Transportation Administration Guidelines
82. 83-66-07 JUL 98 Exhaust Muffler Insulator Rumble Noise
83. 83-15-13 JUL 98 Front Fender to Door Fit/Appearance
84. 83-05-05 JUL 98 Labor Time Guides Updates
85. 73-15-12A JUL 98 Loose Lower Front Fascia Valance Panels
86. 83-96-05 JUL 98 Radio Telephone/Mobile Radio Inst/Troubleshooting
87. 83-90-08 JUN 98 Charts and Schematics for Cruise Control Diagnosis
88. 83-15-11 JUN 98 Discoloration/Staining of Plenum Air Inlet Grille/Panel
89. 83-05-04 JUN 98 Labor Guide Time Update
90. 83-15-05 MAY 98 Door Glass Rattle
91. 82-05-03 MAY 98 Elimination of Labor Op Z7920/Z7930
92. 82-05-05 MAY 98 General Motors Warranty Inquiry System
93. 83-15-07 MAY 98 Hiss Noise Right/Left Door
94. 83-05-03 MAY 98 Labor Time Guide Updates
95. 83-15-09 MAY 98 New Windnoise Diagnostic Procedure
96. 83-71-10 MAY 98 Park/Neutral Switch Conn. Cannot Be Removed
97. 82-05-02 MAY 98 Request for Authorization Using Routing Code H
98. 83-15-08 MAY 98 Waterleak Above Door Glass
99. 83-05-02 APR 98 Labor Time Guide Updates
100. 83-82-07 APR 98 Loose or Missing Headlight Door Bezel Plug
101. 83-34-07 APR 98 Muffled Clatter Noise Coming from Passenger Compartment
102. 87-61-24 APR 98 Use of Surface Conditioning Discs
103. 48-05-01C MAR 98 Customer Concern Not Duplicated /Verified - Labor
104. 83-83-07 MAR 98 Fuel Level Sensor Replacement Procedure
105. 83-05-01 MAR 98 Labor Time Guide Updates
106. 87-65-10 MAR 98 No Start Condition, Non-functional PCM After Programming
107. 83-64-09 MAR 98 Tool J 41450-B Released for CS Generator Diagnosis
108. 83-12-19 MAR 98 Torque Spec. For A/C Compressor Attaching Bolts
109. 83-01-14 MAR 98 VIN Plate Replacement
110. 83-81-24 MAR 98 Various Driveability Conditions
111. 83-15-02 MAR 98 Waterleak and Windnoise Diagnostic Procedures
112. 87-61-13 FEB 98 Belt Rumble Noise at Low Idle Speeds
113. 83-11-10 FEB 98 Blower Motor Run On When Ignition Is Off
114. 63-82-06A FEB 98 Exterior Lamp Condensation / Replacement Guidelines
115. 72-05-09 FEB 98 GM Dealer Empowerment Program
116. 73-05-09 FEB 98 Labor Guide Updates
117. 82-05-01 FEB 98 New Vehicle / Replacement Battery Warranty Instructions
118. 73-50-37 JAN 98 Brake Rotor and Hub Cleaning Tool Revision
119. 72-05-14 JAN 98 Enhanced Sublet Repair Policy
120. 73-90-23 JAN 98 Frontal (SIR) ON-Off Switch Kits, Parts and Procedures
121. 73-05-09 JAN 98 Labor Times Update
122. 72-05-13 JAN 98 Repair/Replace Policies and Procedures
123. 72-05-12 JAN 98 Shock Absorbers and Struts Operations
124. 73-12-12A DEC 97 Diagnostic Procedure When A/C Leak Cannot Be Found
125. 73-05-07 DEC 97 Labor Time Guide Updates
126. 33-17-01A DEC 97 Paint Peeling from Painted Muffler
127. 72-05-11 DEC 97 Rail Dust Removal and Chemical Spotting - labor
128. 71-05-02 DEC 97 Recall Campaign Follow-Up Post Card
129. 73-01-10 DEC 97 Technical Assistance Call Preparation
130. 23-50-05B NOV 97 Brake Rotor Warranty Service Procedure
131. 48-05-01A NOV 97 Customer Concern Not Verified/Duplicated Labor Operation
132. 78-83-03A NOV 97 Identification of the Instrument Cluster
133. 62-05-02A NOV 97 Labor Operation Z1241 - Personal Property Damage
134. 73-05-07 NOV 97 Labor Time Guide Updates
135. 73-12-13 NOV 97 PureGuard 2 Operating Alert
136. 73-81-40 OCT 97 Electrical Center/Diagnostic Information
137. 73-83-22 OCT 97 Erratic Fuel Gauge Readings
138. 73-05-06 OCT 97 Labor Time Guide Addition
139. 73-01-09 OCT 97 Revised Repair Procedures for Inoperative Ign. Cylinders
140. 77-71-66A SEP 97 Automatic Transmission/Transaxle - DTC's
141. 73-10-58 SEP 97 Hatch Will Not Pop Up When Activated in Cold Weather
142. 73-05-06 SEP 97 Labor Time Guide addition
143. 73-62-13A SEP 97 Servicing of Aluminum Heater Cores and/or Radiators
144. 70-05-01 SEP 97 Tire Replacement During Bumper to Bumper Warranty
145. 72-05-04 AUG 97 Guidelines for Claiming C0034 - Windshield Replacement
146. 72-05-06 AUG 97 Guidelines for I/M 240 Labor, J9980-I/M, J9981 and J9982
147. 72-05-05 AUG 97 Guidelines for Using E0420 Wheel Replace
148. 72-05-03 AUG 97 Guidelines for Wheel Alignments and Wheel Balance
149. 73-05-05 AUG 97 Labor Times
150. 73-34-04 AUG 97 Revised Specs/Installation Rear Spring Stud and Height
151. 73-90-13 AUG 97 Synchronizing the Remote Function Actuation Transmitter
152. 73-62-13 JUL 97 Aluminum Heater Core and/or Radiator Replacements
153. 73-62-14 JUL 97 Approved Engine Coolant Recycling Processes
154. 73-11-03 JUN 97 Air Temperature From HVAC Outlets Does Not Change
155. 73-05-04 JUN 97 Labor Time Update
156. 63-17-07B JUN 97 Paint Specification for Basecoat/Clearcoat Paint Systems
157. 73-10-55 JUN 97 Water Drips Into Rear Compartment
158. 33-35-02A MAY 97 Goodyear's Extended Mobility Tire (Servicing Techniques)
159. 73-10-54 MAY 97 Two-Part Urethane Adhesive For Windshield Installations
160. 631208A APR 97 A/C Tool And Equipment Maintenance
161. 73-83-15 APR 97 Fuel Gauge Responds Slowly After Fueling
162. 73-05-03 APR 97 Labor Time Guide Update
163. 730503 APR 97 Labor Times Guide Update
164. 620504 APR 97 Operating Procedures
165. 730107 APR 97 Revised Supplemental Inflatable Restraint Warning labels
166. 731206 MAR 97 A/C Compressor Diagnostic Info Request Before Replace
167. 549001A MAR 97 CLN Indicator On Radio Display
168. 674102 MAR 97 Driveline Support Assembly Exchange Program
169. 677206 MAR 97 Manual Transmission Exchange Program
170. 676540 MAR 97 Pictorial Of Oxygen Sensor Designations
171. 774202 MAR 97 Rear Axle Assembly Exchange Program
172. 736513 MAR 97 Reprogram Capability Using Off Board Program Adapter
173. 731204 FEB 97 Air Conditioning Systems With R12 Or R134a Service Issue
174. 731049 FEB 97 Body Sealer Tape For Collision Repairs
175. 776105 FEB 97 Engine Exchange Program For 5.7L LS1 GEN III V8
176. 730501 FEB 97 Update Labor Time Guide
177. 730502 FEB 97 Updates Labor Time Guide
178. 630507 JAN 97 Updates Labor Time Guides
179. 649601 JAN 97 Compact Disk Players Procedures
180. 436407A JAN 97 Low Voltage Reading Or Dim Lights At Idle
181. 600503 JAN 97 Warranty Repairs And Claims Procedures
182. 62-05-03 DEC 96 Dealer Prohibited Use of Labor Open. and/or Claim Type
183. 63-05-06 DEC 96 Updates to Labor Time Guide
184. 400501A SEP 96 Corporate Parts Return Program Instructions
185. 677151 SEP 96 New Product Information
186. 67-71-49 JUN 96 Revised Text For All DTC Tables
187. 00-05-22-002 FEB 00 (Warranty) Brake Rotor Service Procedure
188. 00-06-04-011 FEB 00 Evaporative Emission Testing on Vehicles
189. 00-00-89-001 FEB 00 February, 2000 Labor Time Guide Updates
190. 99-09-41-004 JAN 00 Air Bag (SIR) On-Off Switch Kits, New Parts and Service
191. 99-00-89-023 JAN 00 January, 2000 Labor Time Guide Updates
192. 99-09-40-004 JAN 00 TOP TETHER HARDWARE PACKAGE FOR CHILD RESTRAINT SEATS
193. 99-08-66-002A JAN 00 TRAP RESISTANT REAR COMPARTMENT (TRUNK) KIT
