Originally posted by Robert Heyl:
The Crank Position relearn process is pretty interesting. Does the power interuption also cause this relearn, or is it only induced by the scanning tool? It would seem an odd situation if a dead battery sets the relearn process and the driver never gets the rpm's to the required level to complete the process.
What is important to know is the crank position is used to determine if there are misfires and which pistons are involved.
If the crank position is not properly learned, false misfires might occurr.
Your right, any loss of power would require any important sensor to be learned, not only for issues like crank, but many of them are part of the math forumlas PCM uses to decide how to tune up fuel trim tables, amount of timing etc.
Also correct if after a loss of power to PCM, if the owner does not know this and not get to that RPM, the test is not completed or can flag false errors.
That's why it is important to know what these electronic controlled engine require.
The scanner, if it has the feature allows the service guy to assure this CKS is learned correctly but can be done via the drive cycle procedure.
