Bulletins for 1999 Chevrolet Corvette V8-350 5.7L VIN G SFI
Service Bulletins
TSB Number Issue Date TSB Title
1. 99-06-03-012 DEC 99 Battery Testing and Replacement
2. 99-00-89-021 DEC 99 December 1999 Labor Time Guide Updates
3. 99-01-38-006 DEC 99 J-43600 ACR2000 Refrigerant Recovery/Recharge Equipment
4. 99-00-89-022 DEC 99 The Year 2000 and Vehicle Electronics
5. 99-08-45-005 NOV 99 Accessory Receptacle/Cigar Lighter is Inoperative
6. 99-00-84-021 NOV 99 Expediting Parts
7. 99-03-10-104 NOV 99 Improper Tire Pressure
8. 99-00-89-020 NOV 99 November 1999 Labor Time Guide Updates
9. 99-08-46-001 NOV 99 OnStar(R) Kit Part Numbers and Compatibility
10. 99-06-04-053 NOV 99 Powertrain Control Module Reprogramming
11. 99-08-42-009 NOV 99 Setting of I/P Dimmer Control to View PRNDL Display
12. 99-01-39-007 OCT 99 Automatic Air Conditioning Control Operation
13. 99-06-03-011 OCT 99 CS-144 Generator Replacement
14. 99-08-44-008 OCT 99 Cassette Player Cleaning and Maintenance
15. 99-06-03-010 OCT 99 DTC's B1001, B1271 or B1780 Set When Replacing Modules
16. 99-06-02-016 OCT 99 Engine Low Coolant Light Comes On At Start-up
17. 99-06-04-052 OCT 99 Left Fuel Tank To Underbody Contact/Rattle Noise
18. 99-07-30-021 OCT 99 New Solenoid Testing Kit For All Hydra-Matic Trans.
19. 99-00-89-017 OCT 99 October, 1999 Labor Time Guide Updates
20. 99-06-02-017 OCT 99 Radiator Repair/Replacement Guidelines
21. 99-08-51-007 OCT 99 Refinishing Aluminum Wheel
22. 99-08-52-005 OCT 99 Remote Keyless Entry Operational Characteristics
23. 99-06-04-043 OCT 99 Revised Diagnostic Table for DTCs P0342 & P0343
24. 99-00-89-019 OCT 99 Warranty Parts Center/Corporate Parts Return Program
25. 99-00-89-016 SEP 99 1994-2000 Labor Time Guide - Updates
26. 99-07-30-017 SEP 99 Auto/Trans Oil Cooler Flushing and Flow Check Procedures
27. 99-07-30-020 SEP 99 Automatic Transmission Service Procedure Change
28. 99-05-24-004 SEP 99 Revised Procedure for DTC C1288 Steering Sensor
29. 99-08-64-016 SEP 99 Use of Silicone for Weatherstrip Maintenance
30. 99-08-49-008 JUL 99 Chime Sounds When Key is Removed From Ignition
31. 000000A JUL 99 GM Service Bulletin Precautions
32. 99-00-89-010 JUL 99 July,1999 Labor Time Guide Updates
33. 99-08-50-010 JUL 99 Premature Wear of Leather on Bucket Seatback Bolster
34. 99-00-89-008 JUN 99 June 1999 Labor Time Guide Updates
35. 99-03-10-102 JUN 99 Original Equipment Chrome Plated Aluminum Wheel ID
36. 99-08-52-004 JUN 99 Revised Transmitter Programming/Synchronization
37. 99-06-01-011 JUN 99 Second Design Connecting Rod Bolt and Torque Specs
38. 99-07-29-001 JUN 99 Squeak Type Noise from Shift Boot When Shifting
39. 99-06-01-007 MAY 99 Accessory Drive Squeak
40. 99-00-89-006 MAY 99 May 1999 Labor Time Guide Updates
41. 99-01-39-006 APR 99 Production Changes to A/C System Components
42. 99-00-89-004 APR 99 1994-2000 Labor Time Guide Updates
43. 99-08-49-006 APR 99 Cleaning of Upper Instrument Panel Surfaces
44. 99-08-51-001 APR 99 Paint-less Dent Repair Process
45. 99-05-25-001 APR 99 Revised Antilock Brake System Diagnostic Procedure
46. 99-06-01-004 APR 99 Revised Dimension for Engine Block Rear Oil Gallery Plug
47. 99-09-41-002 APR 99 Supplemental Inflatable Restraint Light Operation
48. 99-00-89-003 MAR 99 1994-2000 Labor Time Guide Updates
49. 99-06-03-002 MAR 99 Battery Insulator Replacement
50. 99-07-30-005 MAR 99 Component Slipping/DTC P1870 Diagnosis
51. 99-06-03-001 MAR 99 Essential Tool J 42000 Battery Tester
52. 99-06-04-013 MAR 99 New Chassis Fuel System Service Kits
53. 83-81-34 MAR 99 Operating Vehicle with SIR Warning Light On
54. 99-08-50-002 MAR 99 Revised Seatback Cover Removal Procedure
55. 99-00-89-002 MAR 99 Using the New GM Service Bulletins
56. 99-00-89-001 FEB 99 1994-99 Car and Truck Labor Time Guide Updates
57. 99-01-39-004 FEB 99 Air Conditioning Odor
58. 99-06-02-008 FEB 99 Water Pump and Pulley Identification and Usage
59. 83-05-11 JAN 99 1994-99 Labor Time Guide Updates
60. 83-12-21 JAN 99 Contaminated R134a A/C Systems
61. 86-05-02 DEC 98 Delayed Warranty Start Process
62. 83-15-23 DEC 98 Information on Roof Panel Replacement
63. 83-83-17A DEC 98 Instrument Cluster Identification
64. 83-05-10 DEC 98 Labor Guide Updates for 94/99 Cars and Trucks
65. 87-71-74 NOV 98 1-2 Accumulator Piston and Outer Spring Replacement
66. 83-35-08 NOV 98 Chemical Staining of Chrome Wheels
67. 87-71-73A NOV 98 Enhanced 4L60E Technical Assistance
68. 83-05-09 NOV 98 Labor Time Guide Updates for 1994-99 Cars and Trucks
69. 83-32-10 NOV 98 Tool J 43435 Adjuster Locknut Wrench
70. 83-32-09 NOV 98 Tool J 43485 Power Steering Bleeder Adapter
71. 83-17-04 OCT 98 Door Handles on White Painted Vehicles Turning Yellow
72. 83-31-09 OCT 98 Information on Alignment Specifications
73. 83-05-08 OCT 98 Labor Time Guide
74. 83-15-16 OCT 98 New Windshield and Glass Urethane Adhesive Caulking Kit
75. 76-02-02A OCT 98 Recommended Axle Lubricant
76. 83-81-32 SEP 98 Information On New PCM Connector Service Kits
77. 83-05-07 SEP 98 Labor Time Updates
78. 83-83-16 SEP 98 Speedometer Accuracy
79. 76-60-04A AUG 98 Engine Oil Consumption Guideline
80. 83-01-19 AUG 98 Service Manual Delivery on Compact Disc (CD)
81. 00-08-64-004 MAR 00 Window Motor Noisy/Inoperative
82. 00-05-22-002 FEB 00 (Warranty) Brake Rotor Service Procedure
83. 00-06-04-011 FEB 00 Evaporative Emission Testing on Vehicles
84. 00-00-89-001 FEB 00 February, 2000 Labor Time Guide Updates
85. 99-09-41-004 JAN 00 Air Bag (SIR) On-Off Switch Kits, New Parts and Service
86. 00-06-02-001 JAN 00 ENGINE RUNNING HOT, OVERHEATING AND/OR LOSS OF COOLANT
87. 99-00-89-023 JAN 00 January, 2000 Labor Time Guide Updates
88. 99-09-40-004 JAN 00 TOP TETHER HARDWARE PACKAGE FOR CHILD RESTRAINT SEATS
