8/23/25 IMSA at VIR Race
by teamzr1. 08/29/25 03:25 PM
IMSA Road America Aug 3rd
by teamzr1. 08/03/25 02:30 PM
by teamzr1. 08/02/25 07:36 PM
C8 Center Console TSB
by teamzr1. 08/27/25 03:05 PM
What BS Ford Marketing
by teamzr1. 08/21/25 11:28 AM
New C8 ZR1s Stolen Right out of GMs BGP !
by teamzr1. 08/09/25 03:14 PM
C8 ZR1s being Flipped
by teamzr1. 08/07/25 04:16 PM
Sticker Prices for 2026 ZR1-X Models
by teamzr1. 08/06/25 07:11 AM
Topics3,642
Posts6,781
#1382 - 07/22/03 08:51 PM Speed Density Description
Speed Density System Description
The speed density system is only needed when there is a mass air flow (MAF) sensor malfunction.
If the PCM detects a malfunction with the MAF sensor circuit, the PCM will default to speed density fuel management.
Three sensors provide the PCM with the basic information for the fuel management portion of its operation. That is, 3 specific signals to the PCM establish the engine speed and air density factors.
The engine speed signal comes from the ignition system. Air density is derived from IAT and MAP sensor inputs.
The IAT sensor measures the air temperature that is entering the engine. The IAT signal works in conjunction with the MAP sensor to determine air density. As the intake manifold pressure increases, the air density in the intake manifold also increases and additional fuel is required. This information from the IAT and MAP sensors is used by the PCM to control injector pulse width.
#1383 - 11/09/04 08:45 AM Re: Speed Density Description
When/how does the PCM detect a MAF sensor failure?
Keith
#1384 - 11/09/04 12:21 PM Re: Speed Density Description
The PCM compares the MAF output to what they calculated for VE table, if the values are not close then PCM assumes something wrong with MAF and switches to VE tables
If people do not muck around with porting MAF or TB then VE tables are only used for startup and fallback conditions.
Once people screw with the airflow path and/or MAF and VE tables then more chance values do not match forcing PCM to switch back/forth to VE tables.
0 registered members (), 12 guests, and 13 spiders.
by teamzr1. 08/22/25 07:08 AM
2023-26 Z06 and ZR1 GM Recall
by teamzr1. 08/22/25 06:06 AM
