<BIG><FONT face="Verdana, Arial, Helvetica, sans-serif" size=3>Engine Coolant temperature</FONT></BIG></FONT>
<FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>The Engine
Coolant Temperature (ECT) sensor is a two-wire sensor. It is threaded into
the engine coolant jacket, in direct contact with the engine coolant. The
coolant sensor contains a thermistor and provides the PCM with an engine
coolant temperature reading. The PCM provides a 5-volt signal to the ECT
sensor through a dropping resistor. When cold, the sensor provides high
resistance, which the PCM detects as a high signal voltage. As the engine
warms up, the sensor resistance becomes lower, and the signal voltage
drops. Approximate resistance values are shown in the accompanying chart
(figure 3-8). At normal engine operating temperature (85×C to 105×C), the
signal voltage is in the range of 1.0 to 2.0 volts.</FONT>
<FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>The PCM uses
information about coolant temperature to make the necessary calculations
for:</FONT>
<BLOCKQUOTE>
  • <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Fuel
    delivery
    </FONT>
  • <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Ignition
    Control (IC)
    </FONT>
  • <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Knock
    Sensor System (KS)
    </FONT>
  • <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Idle
    speed (IAC)
    </FONT>
  • <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Torque
    Converter Clutch application (TCC)
    </FONT>
  • <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Canister
    purge (EVAP)
    </FONT>
  • <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Exhaust
    Gas Recirculation (EGR)
    </FONT>
  • <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Cooling
    fan operation (some applications)
    </FONT>
    size=2>Others</FONT>
<strong><FONT color=#0080c0>Figure 3-9,</FONT> Engine Coolant Temperature (ECT)Sensor
