Long Term Fuel Trim Description
The long term fuel trim (FT) is a matrix of cells arranged by RPM and MAP. Each cell of the long term FT is a register like the short term FT. As the engine operating conditions change, the PCM will switch from cell to cell to determine what long term FT factor to use in the base pulse width equation.
While in any given cell, the PCM also monitors the short term FT. If the short term FT is far enough from 0 percent, the PCM will change the long term FT value. Once the long term FT value is changed, it should force the short term FT back toward 0 percent. If the mixture is still not correct (as judged by the PCM), the short term FT will continue to have a large deviation from the ideal 0 percent. In this case, the long term FT value will continue to change until the short term FT becomes balanced. Both the short term FT and long term FT have limits which vary by calibration. If the mixture is off enough so that long term FT reaches the limit of its control and still cannot correct the condition, the short term FT would also go to its limit of control in the same direction. If the mixture is still not corrected by both short term FT and long term FT at their extreme values, a FT DTC will likely result. When the PCM determines that the long term FT is out of the operating range, the following DTCs will set:
DTC P0171 FT System Lean Bank 1
DTC P0172 FT System Rich Bank 1
DTC P0174 FT System Lean Bank 2
DTC P0175 FT System Rich Bank 2
Under the conditions of power enrichment, the PCM sets the short term FT to 0 percent and freezes it there until power enrichment is no longer in effect.
This is done so the Closed Loop factor and the long term FT will not try to correct for the commanded richness of power enrichment.
