Topics3,615
Posts6,713
#1413 - 08/29/01 11:18 AM Removing PCM power and clearing error codes
When the power to the PCM is removed, depending on how long the power is removed would dicate how much of what is in PCM memory is lost or removed.
Some people think that by disconnecting the main car battery for a few minutes will clear everything out, when in fact it can takes several hours for everything to be drained due to no power to the PCM.
If the battery power to the PCM is removed for a period of several hours, all trouble codes, freeze frame data, fail records, last test failed messages and the I/M Readiness status are lost.
Note: This is not a recommended method to clear the memory of the PCM to clear codes because this action will cause the Diagnostic Executive (PCM) to lose all of its diagnostic test records.
On G.M cars, the PCM clears a code when it determines that FORTY warmup cycles have occurred without a fault since the MIL was turned off.
#1414 - 08/29/01 04:05 PM Re: Removing PCM power and clearing error codes
This makes me wonder ... when my car was stored, it lost all battery power for several months. I wonder how many systems have not yet been re-learned? I know for a fact that I haven't done the steps that you outlined to re-learn the Idle, and not too sure if I have ran the rpms to the required 5100 or whatever for the crank position. eek
#1415 - 08/30/01 09:33 PM Re: Removing PCM power and clearing error codes
The C4s did not have as many requirements for OBD-II monitors to be running tests.
OBD-II regulations were beefed up even more in 1999 and thus a 1996 C4 would not have the same issues as testing in an incomplete state.
The only way to really know the state of all these test monitors is to be using a OBD-II scanner able to view these tests and report what state they are in.
0 registered members (), 15 guests, and 15 spiders.
