B0001
Vehicle Speed Information Circuit Range/Performance
Navigation Radio
DTC B0001
B0005
In Park Switch Circuit
BCM, SCLCM
DTC B0005
B0012
Passenger Frontal Deployment Loop Stage 2 Resistance Low
SDM
DTC B0012, B0013, B0014, B0016, B0017, or B0018
B0013
Passenger Frontal Deployment Loop Stage 2 Open
SDM
B0014
Passenger Frontal Deployment Loop Stage 2 Voltage Out of Range
SDM
B0016
Passenger Frontal Deployment Loop Stage 1 Resistance Low
SDM
B0017
Passenger Frontal Deployment Loop Stage 1 Open
SDM
B0018
Passenger Frontal Deployment Loop Stage 1 Voltage Out of Range
SDM
B0022
Driver Frontal Deployment Loop Stage 1 Resistance Low
SDM
DTC B0022, B0024, B0026, B0042, B0043, or B0044
B0024
Driver Frontal Deployment Loop Stage 1 Voltage Out of Range
SDM
B0026
Driver Frontal Deployment Loop Stage 1 Open
SDM
B0028
Right Front Side Deployment Loop Resistance Low
SDM
DTC B0028, B0029, or B0030
B0029
Right Front Side Deployment Loop Open
SDM
B0030
Right Front Side Deployment Loop Voltage Out of Range
SDM
B0040
Left Front Side Deployment Loop Resistance Low
SDM
DTC B0040, B0041, or B0045
B0041
Left Front Side Deployment Loop Open
SDM
B0042
Driver Frontal Deployment Loop Stage 2 Resistance Low
SDM
B0043
Driver Frontal Deployment Loop Stage 2 Voltage Out of Range
SDM
B0044
Driver Frontal Deployment Loop Stage 2 Open
SDM
B0045
Left Front Side Deployment Loop Voltage Out of Range
SDM
B0051
Deployment Commanded
SDM
DTC B0051
B0053
Deployment Commanded with Loop DTCs Present
SDM
DTC B0053
B0057
Right Front Pretensioner Deployment Loop Resistance Low
SDM
DTC B0057, B0058, or B0059
B0058
Right Front Pretensioner Deployment Loop Open
SDM
B0059
Right Front Pretensioner Deployment Loop Voltage Out of Range
SDM
B0064
Left Front Pretensioner Deployment Loop Resistance Low
SDM
DTC B0064, B0065, or B0066
B0065
Left Front Pretensioner Deployment Loop Open
SDM
B0066
Left Front Pretensioner Deployment Loop Voltage Out of Range
SDM
B0077
Driver Side Impact Sensor (SIS) Performance
SDM
DTC B0077, B0078, B0079, B0080, B0081, or B0082
B0078
Passenger Side Impact Sensor (SIS) Performance
SDM
B0079
Incorrect Driver Side Impact Sensor (SIS) Installed
SDM
B0080
Discard Driver Side Impact Sensor (SIS)
SDM
B0081
Incorrect Passenger Side Impact Sensor (SIS) Installed
SDM
B0082
Discard Passenger Side Impact Sensor (SIS)
SDM
B0083
Right Front Seat Position Sensor Circuit
SDM
DTC B0083 or B0084
B0084
Left Front Seat Position Sensor Circuit
SDM
DTC B0083 or B0084
B0092
Passenger Presence System Performance
SDM
DTC B0092
B0098
Passenger Presence System Configuration Error
SDM
DTC B0098
B0100
Front End Sensor 1 Performance
SDM
DTC B0100, B0101, B0102, B0103, B0104, or B0105
B0101
Discard Front End Sensor 1
SDM
B0102
Incorrect Front End Sensor 1 Installed
SDM
B0103
Front End Sensor 2 Performance
SDM
B0104
Discard Front End Sensor 2
SDM
B0105
Incorrect Front End Sensor 2 Installed
SDM
B0159
Outside Air Temperature Sensor Circuit
HVAC
DTC B0159 or B0164
B0164
Passenger Compartment Temperature Sensor Circuit
HVAC
DTC B0159 or B0164
B0174
Output Air Temperature Sensor 1
HVAC
DTC B0174, B0179, B0510, or B0515
B0179
Output Air Temperature Sensor 2
HVAC
B0184
Solar Load Sensor 1 Circuit Performance
HVAC
DTC B0184 or B0189
B0189
Solar Load Sensor 2 Circuit Performance
HVAC
DTC B0184 or B0189
B0248
Air Flow Control 3 Circuit
HVAC
DTC B0248, B0268, B0408, or B0423
B0249
Air Flow Control 3 Circuit Range
HVAC
DTC B0249, B0269, B0409, or B0419
B0268
Air Flow Control 7 Circuit
HVAC
B0269
Air Flow Control 7 and Circuit Range
HVAC
B0408
Temperature Control 1 Circuit
HVAC
B0409
Temperature Control 1 Circuit Range
HVAC
B0419
Temperature Control 2 Circuit Range
HVAC
B0423
HVAC
B0510
Output Air Temperature Sensor 3
HVAC
B0515
Output Air Temperature Sensor 4
HVAC
B0540
Speedometer Circuit
IPC
DTC B0540
B0560
Tachometer Circuit
IPC
DTC B0560
B0976
Power Mode OFF Indicator Circuit
BCM
DTC B0976, B0977, or B0978
B0977
Power Mode START Indicator Circuit
BCM
B0978
Power Mode ACCESSORY Indicator Circuit
BCM
B1000
Electronic Control Unit (ECU) Performance
DSCC, BCM, DDM, DRR, RCDLR, FTC, HUD, HVAC, IPC, PDM, Radio, SCLCM, SDM, VCIM
DTC B1000
B1001
Option Configuration Error
BCM
DTC B1001
DRR, Radio
DTC B1001
SDM
DTC B1001
VCIM
DTC B1001
B1004
Keep Alive Memory (KAM) Reset
Audio Amplifier, DDS, HVAC, SCLCM, VCIM
DTC B1004
B1007
EEPROM Write Error
Audio Amplifier, DDS, DPM, FTC, SCLCM
DTC B1007
B1009
EEPROM Checksum Mismatch
Audio Amplifier, DDS, DPM, FTC, SCLCM, VCIM
DTC B1009
B1011
System Disabled Information Stored
DDM, PDM
DTC B1011
FTC
DTC B1011
B1013
Calibration Read Only Memory (ROM) Checksum Error
HVAC
DTC B1013
B1014
Program Read Only Memory (ROM) Checksum Error
HVAC
DTC B1014
B1271
Theft Locked
Radio
DTC B1271
B1291
Convertible Top Fifth Bow Position
FTC
DTC B1291
B1325
Device Power 1 Circuit Voltage
BCM
DTC B1325
B1327
Device Power 1 Circuit Low
Audio Amplifier, DRR, DPM, FTC, HVAC, SDM, SCLCM, VCIM, DDS
DTC B1327
B1328
Device Power 1 Circuit High
Audio Amplifier, FTC, HVAC, SCLCM, SDM
DTC B1328
B1336
Device Power 3 Circuit Range/Performance
DPM/MSM
DTC B1336
B1370
Device Ignition 1 Circuit
RCDLR
DTC B1370
B1420
Device Voltage
DDM, PDM
DTC B1420
DPM/MSM
DTC B1420
FTC
DTC B1420
B1440
Power Mode Master Input Circuits Mismatch
RCDLR
DTC B1440
B1451
Accessory Power Circuit
BCM
DTC B1451
B1474
Right Front Exterior Door Handle Switch Circuit
DDM, PDM, RCDLR
DTC B1474, B2981, B3848, or B3849
B1480
Battery Rundown Protection Circuit
BCM
DTC B1480
B1580
Left Front Mirror Horizontal Position Sensor Circuit
DDM, PDM
DTC B1580 or B1590
B1590
Left Front Mirror Vertical Position Sensor Circuit
DDM, PDM
DTC B1580 or B1590
B1600
Mirror Motor 1 Circuit
DDM, PDM
DTC B1600 or B1605
B1605
Mirror Motor 2 Circuit
DDM, PDM
DTC B1600 or B1605
B1697
Mirror Left-Up Control Switch Circuit Low
DDSA
DTC B1697, B1702, B1707, or B1712
B1702
Mirror Left-Down Control Switch Circuit Low
DDSA
B1707
Mirror Right-Up Control Switch Circuit Low
DDSA
B1712
Mirror Right-Down Control Switch Circuit Low
DDSA
B1735
Seat Front Up Switch Circuit
DPM/MSM
DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, or B1820
B1740
Seat Front Down Switch Circuit
DPM/MSM
B1745
Seat Rear Up Switch Circuit
DPM/MSM
B1750
Seat Rear Down Switch Circuit
DPM/MSM
B1755
Seat Assembly Horizontal Forward Switch Circuit
DPM/MSM
B1760
Seat Assembly Horizontal Rearward Switch Circuit
DPM/MSM
B1815
Seat Recline Forward Switch Circuit
DPM/MSM
B1820
Seat Recline Rearward Switch Circuit
DPM/MSM
B1825
Seat Recline Position Sensor Circuit
DPM/MSM
DTC B1825, B1850, B2355, B2365, or B2375
B1826
Seat Recline Position Sensor Circuit Range/Performance
DPM/MSM
DTC B1826, B1851, B1861, B2356, B2366, or B2376
B2355
Seat Front Vertical Position Sensor Circuit
DPM/MSM
B2356
Seat Front Vertical Position Sensor Circuit Range/Performance
DPM/MSM
B2365
Seat Rear Vertical Position Sensor Circuit
DPM/MSM
B2366
Seat Rear Vertical Position Sensor Circuit Range/Performance
DPM/MSM
B2375
Seat Assembly Horizontal Position Sensor Circuit
DPM/MSM
B2376
Seat Assembly Horizontal Position Sensor Circuit Range/Performance
DPM/MSM
B2455
Cellular Phone Microphone Circuit
VCIM
DTC B2455
B2462
Global Positioning System (GPS) Signal Error
Navigation Radio
DTC B2462
B2470
Cellular Phone Antenna Circuit
VCIM
DTC B2470
B2476
Cellular Phone Select Service Switch
VCIM
DTC B2476
B2482
Cellular Phone Select Service Switch Performance
VCIM
DTC B2482
B2483
Global Positioning System (GPS) Sensor Circuit Low
VCIM
DTC B2483 or B2484
B2484
Global Positioning System (GPS) Sensor Circuit Open
VCIM
DTC B2483 or B2484
B2510
Steering Column Lock Motor Unlock Circuit
SCLCM
DTC B2510
B2515
Steering Column Lock Motor Feedback Circuit
SCLCM
DTC B2515
B2517
Left Front Door Latch Circuit
DDM, PDM
DTC B2517 or B2518
B2518
Right Front Door Latch Circuit
DDM, PDM
DTC B2517 or B2518
B2530
Front Foglamps Control Circuit
BCM
DTC B2530
B2540
Rear Foglamps Control Circuit
BCM
DTC B2540
B2580
Headlamp High Beam Control Circuit
BCM
DTC B2580
B2625
Display Dimming Pulse Width Modulation (PWM) Output Circuit
BCM
DTC B2625
B2710
Gearshift Lock Circuit
RCDLR
DTC B2710
B2750
Horn Relay Coil Circuit
BCM
DTC B2750
B2757
Memory 1 Select Switch Circuit Low
DDM
DTC B2757, B2762, B2767, or B2772
B2762
Memory 2 Select Switch Circuit Low
DDM
B2853
Telescope Forward Switch Circuit High
DPM/MSM
DTC B2853, B2858, B2873, or B2878
B2858
Telescope Rearward Switch Circuit High
DPM/MSM
B2860
Telescope Position Sensor
DPM/MSM
DTC B2860
B2897
Steering Column Lock Motor Lock Circuit
SCLCM
DTC B2897
B2907
Steering Column Lock Motor Enable Relay Circuit
BCM, SCLCM
DTC B2907
B2910
Steering Column Lock Password Incorrect
SCLCM
DTC B2910
B2981
Right Front Door Handle Switch Circuit
DDM, PDM, RCDLR
B3089
Content Theft System Intrusion Sensor Signal Circuit
BCM
DTC B3089
B3119
Keyless Entry Antenna 1 Performance
RCDLR
DTC B3119
B3120
Keyless Entry Antenna 2 Performance
RCDLR
DTC B3120
B3121
Keyless Entry Antenna 3 Performance
RCDLR
DTC B3121
B3122
Keyless Entry Antenna 4 Performance
RCDLR
DTC B3122
B3142
Left Front Unlock Switch Circuit Low
DDSA
DTC B3142 or B3152
B3145
Right Front Unlock Switch Circuit Low
PDM
DTC B3145 or B3155
B3152
Left Front Lock Switch Circuit Low
DDSA
DTC B3142 or B3152
B3155
Right Front Lock Switch Circuit Low
PDM
DTC B3145 or B3155
B3170
Right Front Window Up Switch Circuit
PDM
DTC B3170, B3175, or B3280
B3175
Right Front Window Down Switch Circuit
PDM
B3205
Left Front Window Motor Circuit
DDM
DTC B3205
B3265
Trunk Release Output Circuit Short to Battery
BCM
DTC B3265
B3280
Right Front Window Express Up or Down Circuit
PDM
B3377
Left Front Window Up Switch Circuit Low
DDSA
DTC B3377, B3382, B3387, B3392, B3467, or B3472
B3382
Left Front Window Down Switch Circuit Low
DDSA
B3387
Right Front Window Up Switch Circuit Low
DDSA
B3392
Right Front Window Down Switch Circuit Low
DDSA
B3467
Left Front Window Express Up or Down Circuit Low
DDSA
B3472
Right Front Window Express Up or Down Circuit Low
DDSA
B3542
Left Front Window Obstruction Sensor Control Circuit
DDM, PDM
DTC B3542
B3602
Convertible Top Control Switch
FTC
DTC B3602
B3618
Exterior Trunk Release Switch Circuit Low
BCM
DTC B3618
B3619
Head-Up Display (HUD) Change Page Switch Circuit
HUD
DTC B3619
B3620
Head Up Display (HUD) Information Up Switch Circuit
HUD
DTC B3620
B3621
Head Up Display (HUD) Information Down Switch Circuit
HUD
DTC B3621
B3634
Head Up Display (HUD) Dimming (Up) Switch Circuit
HUD
DTC B3634
B3659
Head Up Display (HUD) Dimming Down Switch Circuit
HUD
DTC B3659
B3666
Rear Tonneau Position Error
FTC
DTC B3666
B3670
Pump Motor Temperature Sensor Circuit
FTC
DTC B3670
B3715
Front Wiper Relay Drive Circuit
BCM
DTC B3715
B3744
Head Up Display (HUD) Mode Switch Circuit
HUD
DTC B3744
B3794
Cruise Control Function Request Circuit
BCM
DTC B3794
B3810
Headlamp Washer Relay Circuit
BCM
DTC B3810
B3848
Interior Door Handle Switch Circuit
DDM, PDM, RCDLR
B3849
Left Front Exterior Door Handle Switch Circuit
DDM, PDM, RCDLR
B3948
Left Front Turn Signal Circuit
BCM
DTC B3948
B3949
Right Front Turn Signal Circuit
BCM
DTC B3949
B3950
Left Rear Turn Signal Circuit
BCM
DTC B3950
B3951
Right Rear Turn Signal Circuit
BCM
DTC B3951
B3971
Folding Top Position Sensor
FTC
DTC B3971
C0035
Left Front Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0040
Right Front Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0045
Left Rear Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0050
Right Rear Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0110
Pump Motor Circuit
EBCM
DTC C0110
C0136
Base Brake System Pressure Circuit
EBCM
DTC C0136
C0137
Base Brake System Pressure Circuit Range
EBCM
DTC C0137
C0161
Antilock Brake System (ABS)/Traction Control System (TCS) Brake Switch Circuit
EBCM
DTC C0161
C0179
System Thermal High
EBCM
DTC C0179
C0186
Lateral Accelerometer Circuit
EBCM
DTC C0186
C0196
Yaw Rate Circuit
EBCM
DTC C0196
C0220
Left Front Antilock Brake System (ABS) Channel in Release too Long
EBCM
DTC C0220-C0229
C0221
Right Front Antilock Brake System (ABS) Channel in Release too Long
EBCM
DTC C0220-C0229
C0228
Left Rear Antilock Brake System (ABS) Channel in Release too Long
EBCM
DTC C0220-C0229
C0229
Right Rear Antilock Brake System (ABS) Channel in Release too Long
EBCM
DTC C0220-C0229
C0240
Powertrain Control Module (PCM) Traction Control Not Allowed
EBCM
DTC C0240 or P0856
C0242
Powertrain Control Module (PCM) Indicated TCS Malfunction
EBCM
DTC C0242
C0249
Left Normal Force Error
EBCM
DTC C0249 or C0250
C0250
Right Normal Force Error
EBCM
DTC C0249 or C0250
C0252
Vehicle Stability Enhancement System (VSES) Sensors Uncorrelated
EBCM
DTC C0252
C0253
Centering Error
EBCM
DTC C0253
C0267
Low Brake Fluid Indicated
EBCM
DTC C0267
C0277
Brake Pedal Position Sensor Circuit
BCM
DTC C0277
C0278
Brake Pedal Position Sensor Not Calibrated
BCM
DTC C0278
C0281
Dynamic Rear Proportioning (DRP) Performance
EBCM
DTC C0281
C0450
Steering Assist Control Solenoid/Motor/Actuator Circuit
EBCM
DTC C0450
C0550
EBCM
DTC C0550
ESC
DTC C0550
C0551
EBCM
DTC C0551
C0558
Calibration Data Not Programmed
ESC
DTC C0558
C0561
EBCM
DTC C0561
C0565
Vehicle Identification Number (VIN) Information Error
EBCM
DTC C0565
C0575
Left Front Actuator Circuit
ESC
DTC C0575, C0580, C0585, or C0590
C0580
Right Front Actuator Circuit
ESC
C0585
Left Rear Actuator Circuit
ESC
C0590
Right Rear Actuator Circuit
ESC
C0615
Left Front Position Sensor Circuit
ESC
DTC C0615, C0620, C0625 or C0630
C0620
Right Front Position Sensor Circuit
ESC
C0625
Left Rear Position Sensor Circuit
ESC
C0630
Right Rear Position Sensor Circuit
ESC
C0696
Position Sensor Overcurrent (5-volt supply)
ESC
DTC C0696
C0710
Steering Position Signal
RCDLR
DTC C0710
C0750
Left Front Low Tire Pressure Sensor
RCDLR
DTC C0750, C0755, C0760, or C0765
C0755
Right Front Low Tire Pressure Sensor
RCDLR
C0760
Left Rear Low Tire Pressure Sensor
RCDLR
C0765
Right Rear Low Tire Pressure Sensor
RCDLR
C0820
EBCM Case Voltage
EBCM
DTC C0820
C0870
Device Voltage Reference Output 1 Circuit
BCM
DTC C0870
EBCM
DTC C0870
C0895
Device Voltage
ESC
DTC C0895
C0899
Device 1 Voltage Low
EBCM
DTC C0899
C0900
Device 1 Voltage High
EBCM
DTC C0900
P0016
Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
ECM
DTC P0016 for the 6.0L engine
or
DTC P0016 for the 7.0L engine
P0030
HO2S Heater Control Circuit Bank 1 Sensor 1
ECM
DTC P0030, P0036, P0050, or P0056 for the 6.0L engine
or
DTC P0030, P0036, P0050, or P0056 for the 7.0L engine
P0036
HO2S Heater Control Circuit Bank 1 Sensor 2
ECM
or
P0050
HO2S Heater Control Circuit Bank 2 Sensor 1
ECM
or
P0053
HO2S Heater Resistance Bank 1 Sensor 1
ECM
DTC P0053, P0054, P0059, or P0060 for the 6.0L engine
or
DTC P0053, P0054, P0059, or P0060 for the 7.0L engine
P0054
HO2S Heater Resistance Bank 1 Sensor 2
ECM
or
P0056
HO2S Heater Control Circuit Bank 2 Sensor 2
ECM
or
P0059
HO2S Heater Resistance Bank 2 Sensor 1
ECM
or
P0060
HO2S Heater Resistance Bank 2 Sensor 2
ECM
or
P0068
Throttle Body Airflow Performance
ECM
DTC P0068 for the 6.0L engine
or
DTC P0068 for the 7.0L engine
P0101
Mass Air Flow (MAF) Sensor Performance
ECM
DTC P0101 for the 6.0L engine
or
DTC P0101 for the 7.0L engine
P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
ECM
DTC P0102 for the 6.0L engine
or
DTC P0102 for the 7.0L engine
P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
ECM
DTC P0103 for the 6.0L engine
or
DTC P0103 for the 7.0L engine
P0106
Manifold Absolute Pressure (MAP) Sensor Performance
ECM
DTC P0106 for the 6.0L engine
or
DTC P0106 for the 7.0L engine
P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
ECM
DTC P0107 for the 6.0L engine
or
DTC P0107 for the 7.0L engine
P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
ECM
DTC P0108 for the 6.0L engine
or
DTC P0108 for the 7.0L engine
P0112
Intake Air Temperature (IAT) Sensor Circuit Low Voltage
ECM
DTC P0112 for the 6.0L engine
or
DTC P0112 for the 7.0L engine
P0113
Intake Air Temperature (IAT) Sensor Circuit High Voltage
ECM
DTC P0113 for the 6.0L engine
or
DTC P0113 for the 7.0L engine
P0116
Engine Coolant Temperature (ECT) Sensor Performance
ECM
DTC P0116 for the 6.0L engine
or
DTC P0116 for the 7.0L engine
P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
ECM
DTC P0117 for the 6.0L engine
or
DTC P0117 for the 7.0L engine
P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
ECM
DTC P0118 for the 6.0L engine
or
DTC P0118 for the 7.0L engine
P0120
Throttle Position (TP) Sensor 1 Circuit
ECM
DTC P0120 for the 6.0L engine
or
DTC P0120 for the 7.0L engine
P0121
Throttle Position (TP) Sensor 1 Performance
ECM
DTC P0121 for the 6.0L engine
or
DTC P0121 for the 7.0L engine
P0122
Throttle Position (TP) Sensor 1 Circuit Low Voltage
ECM
DTC P0122 for the 6.0L engine
or
DTC P0122 for the 7.0L engine
P0123
Throttle Position (TP) Sensor 1 Circuit High Voltage
ECM
DTC P0123 for the 6.0L engine
or
DTC P0123 for the 7.0L engine
P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
ECM
DTC P0128 for the 6.0L engine
or
DTC P0128 for the 7.0L engine
P0131
HO2S Circuit Low Voltage Bank 1 Sensor 1
ECM
DTC P0131 or P0151 for the 6.0L engine
or
DTC P0131 or P0151 for the 7.0L engine
P0132
HO2S Circuit High Voltage Bank 1 Sensor 1
ECM
DTC P0132 or P0152 for the 6.0L engine
or
DTC P0132 or P0152 for the 7.0L engine
P0133
HO2S Slow Response Bank 1 Sensor 1
ECM
DTC P0133 or P0153 for the 6.0L engine
or
DTC P0133 or P0153 for the 7.0L engine
P0134
HO2S Circuit Insufficient Activity Bank 1 Sensor 1
ECM
DTC P0134 or P0154 for the 6.0L engine
or
DTC P0134 or P0154 for the 7.0L engine
P0135
HO2S Heater Performance Bank 1 Sensor 1
ECM
DTC P0135, P0141, P0155, or P0161 for the 6.0L engine
or
DTC P0135, P0141, P0155, or P0161 for the 7.0L engine
P0137
HO2S Circuit Low Voltage Bank 1 Sensor 2
ECM
DTC P0137 or P0157 for the 6.0L engine
or
DTC P0137 or P0157 for the 7.0L engine
P0138
HO2S Circuit High Voltage Bank 1 Sensor 2
ECM
DTC P0138 or P0158 for the 6.0L engine
or
DTC P0138 or P0158 for the 7.0L engine
P0140
HO2S Circuit Insufficient Activity Bank 1 Sensor 2
ECM
DTC P0140 or P0160 for the 6.0L engine
or
DTC P0140 or P0160 for the 7.0L engine
P0141
HO2S Heater Performance Bank 1 Sensor 2
ECM
or
P0151
HO2S Circuit Low Voltage Bank 2 Sensor 1
ECM
or
P0152
HO2S Circuit High Voltage Bank 2 Sensor 1
ECM
or
P0153
HO2S Slow Response Bank 2 Sensor 1
ECM
or
P0154
HO2S Circuit Insufficient Activity Bank 2 Sensor 1
ECM
or
P0155
HO2S Heater Performance Bank 2 Sensor 1
ECM
or
P0157
HO2S Circuit Low Voltage Bank 2 Sensor 2
ECM
or
P0158
HO2S Circuit High Voltage Bank 2 Sensor 2
ECM
or
P0160
HO2S Circuit Insufficient Activity Bank 2 Sensor 2
ECM
or
P0161
HO2S Heater Performance Bank 2 Sensor 2
ECM
or
P0171
Fuel Trim System Lean Bank 1
ECM
DTC P0171 or P0174 for the 6.0L engine
or
DTC P0171 or P0174 for the 7.0L engine
P0172
Fuel Trim System Rich Bank 1
ECM
DTC P0172 or P0175 for the 6.0L engine
or
DTC P0172 or P0175 for the 7.0L engine
P0174
Fuel Trim System Lean Bank 2
ECM
or
P0175
Fuel Trim System Rich Bank 2
ECM
or
P0201
Injector 1 Control Circuit
ECM
DTC P0201, P0202, P0203, P0204, P0205, P0206, P0207, or P0208 for the 6.0L engine
or
DTC P0201, P0202, P0203, P0204, P0205, P0206, P0207, or P0208 for the 7.0L engine
P0202
Injector 2 Control Circuit
ECM
or
P0203
Injector 3 Control Circuit
ECM
or
P0204
Injector 4 Control Circuit
ECM
or
P0205
Injector 5 Control Circuit
ECM
or
P0206
Injector 6 Control Circuit
ECM
or
P0207
Injector 7 Control Circuit
ECM
or
P0208
Injector 8 Control Circuit
ECM
or
P0218
Transmission Fluid Overtemperature
TCM
DTC P0218
P0220
Throttle Position (TP) Sensor 2 Circuit
ECM
DTC P0220 for the 6.0L engine
or
DTC P0220 for the 7.0L engine
P0222
Throttle Position (TP) Sensor 2 Circuit Low Voltage
ECM
DTC P0222 for the 6.0L engine
or
DTC P0222 for the 7.0L engine
P0223
Throttle Position (TP) Sensor 2 Circuit High Voltage
ECM
DTC P0223 for the 6.0L engine
or
DTC P0223 for the 7.0L engine
P0230
Fuel Pump Relay Control Circuit
ECM
DTC P0230 for the 6.0L engine
or
DTC P0230 for the 7.0L engine
P0300
Engine Misfire Detected
ECM
DTC P0300 - P0308 for the 6.0L engine
or
DTC P0300 - P0308 for the 7.0L engine
P0301
Cylinder 1 Misfire Detected
ECM
or
P0302
Cylinder 2 Misfire Detected
ECM
or
P0303
Cylinder 3 Misfire Detected
ECM
or
P0304
Cylinder 4 Misfire Detected
ECM
or
P0305
Cylinder 5 Misfire Detected
ECM
or
P0306
Cylinder 6 Misfire Detected
ECM
or
P0307
Cylinder 7 Misfire Detected
ECM
or
P0308
Cylinder 8 Misfire Detected
ECM
or
P0315
Crankshaft Position (CKP) System Variation Not Learned
ECM
DTC P0315 for the 6.0L engine
or
DTC P0315 for the 7.0L engine
P0324
Knock sensor (KS) Module Performance
ECM
DTC P0324, P0325, P0326, P0327, P0328, P0330, P0331, P0332, or P0333 for the 6.0L engine
or
DTC P0324, P0325, P0326, P0327, P0328, P0330, P0331, P0332, or P0333 for the 7.0L engine
P0325
Knock Sensor (KS) Circuit
ECM
or
P0326
Knock Sensor (KS) Performance
ECM
or
P0327
Knock Sensor (KS) Circuit Low Frequency
ECM
or
P0328
Knock sensor (KS) Circuit High Frequency
ECM
or
P0330
ECM
or
P0331
ECM
or
P0332
ECM
or
P0333
ECM
or
P0335
Crankshaft Position (CKP) Sensor Circuit
ECM
DTC P0335 or P0336 for the 6.0L engine
or
DTC P0335 or P0336 for the 7.0L engine
P0336
Crankshaft Position (CKP) Sensor Performance
ECM
or
P0340
Camshaft Position (CMP) Sensor Circuit
ECM
DTC P0340 for the 6.0L engine
or
DTC P0340 for the 7.0L engine
P0341
Camshaft Position (CMP) Sensor Performance
ECM
DTC P0341 for the 6.0L engine
or
DTC P0341 for the 7.0L engine
P0351
Ignition Coil 1 Control Circuit
ECM
DTC P0351-P0358 for the 6.0L engine
or
DTC P0351-P0358 for the 7.0L engine
P0352
Ignition Coil 3 Control Circuit
ECM
or
P0353
ECM
or
P0354
Ignition Coil 4 Control Circuit
ECM
or
P0355
Ignition Coil 5 Control Circuit
ECM
or
P0356
Ignition Coil 6 Control Circuit
ECM
or
P0357
Ignition Coil 7 Control Circuit
ECM
or
P0358
Ignition Coil 8 Control Circuit
ECM
or
P0420
Catalyst System Low Efficiency Bank 1
ECM
DTC P0420 or P0430 for the 6.0L engine
or
DTC P0420 or P0430 for the 7.0L engine
P0430
Catalyst System Low Efficiency Bank 2
ECM
or
P0442
Evaporative Emission (EVAP) System Small Leak Detected
ECM
DTC P0442 for the 6.0L engine
or
DTC P0442 for the 7.0L engine
P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
ECM
DTC P0443 for the 6.0L engine
or
DTC P0443 for the 7.0L engine
P0446
Evaporative Emission (EVAP) Vent System Performance
ECM
DTC P0446 for the 6.0L engine
or
DTC P0446 for the 7.0L engine
P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
ECM
DTC P0449 for the 6.0L engine
or
DTC P0449 for the 7.0L engine
P0451
Fuel Tank Pressure (FTP) Sensor Performance
ECM
DTC P0451 for the 6.0L engine
or
DTC P0451 for the 7.0L engine
P0452
Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
ECM
DTC P0452 for the 6.0L engine
or
DTC P0452 for the 7.0L engine
P0453
Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
ECM
DTC P0453 for the 6.0L engine
or
DTC P0453 for the 7.0L engine
P0454
Fuel Tank Pressure (FTP) Sensor Circuit Intermittent
ECM
DTC P0454 for the 6.0L engine
or
DTC P0454 for the 7.0L engine
P0455
Evaporative Emission (EVAP) System Large Leak Detected
ECM
DTC P0455 for the 6.0L engine
or
DTC P0455 for the 7.0L engine
P0461
Fuel Level Sensor 1 Performance
ECM
DTC P0461
P0462
Fuel Level Sensor 1 Circuit Low Voltage
ECM
DTC P0462
P0463
Fuel Level Sensor 1 Circuit High Voltage
ECM
DTC P0463
P0464
Fuel Level Sensor Circuit Intermittent
ECM
DTC P0464
P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
ECM
DTC P0496 for the 6.0L engine
or
DTC P0496 for the 7.0L engine
P0502
Vehicle Speed Sensor (VSS) Circuit Low Voltage
ECM
DTC P0502 for the Tremec 6-Speed transmission
P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
ECM
DTC P0503 for the Tremec 6-Speed transmission
P0506
Idle Speed Low
ECM
DTC P0506 for the 6.0L engine
or
DTC P0506 for the 7.0L engine
P0507
Idle Speed High
ECM
DTC P0507 for the 6.0L engine
or
DTC P0507 for the 7.0L engine
P0521
Engine Oil Pressure (EOP) Sensor Performance
ECM
DTC P0521
P0522
Engine Oil Pressure (EOP) Sensor Circuit Low Voltage
ECM
DTC P0522
P0523
Engine Oil Pressure (EOP) Sensor Circuit High Voltage
ECM
DTC P0523
P0532
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
ECM
DTC P0532 or P0533
P0533
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
ECM
DTC P0532 or P0533
P0562
System Voltage Low
ECM
DTC P0562
TCM
DTC P0562 or P0563
P0563
System Voltage High
ECM
DTC P0563
TCM
DTC P0562 or P0563
P0572
Brake Switch Circuit 1 Low Voltage
ECM
DTC P0572
P0573
Brake Switch Circuit 1 High Voltage
ECM
DTC P0573
P0575
Cruise Control Switch Signal Circuit
ECM
DTC P0575
P0601
Control Module Read Only Memory (ROM)
ECM
DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P060E, P062F, P1600, P1621, P1627, P1681, P1683, or P2610 for the 6.0L engine
or
DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P060E, P062F, P1600, P1621, P1627, P1681, P1683, or P2610 for the 7.0L engine
Transmission Control Module (TCM) Read Only Memory (ROM)
TCM
DTC P0601, P0602, P0603, P0604, or P1621
P0602
Control Module Not Programmed
ECM
or
Transmission Control Module (TCM) Not Programmed
TCM
P0603
Control Module Long Term Memory Reset
ECM
or
Transmission Control Module (TCM) Long Term Memory Reset
TCM
P0604
Control Module Random Access Memory (RAM)
ECM
or
Transmission Control Module (TCM) Random Access Memory (RAM)
TCM
P0606
Control Module Internal Performance
ECM
or
P0607
Control Module Performance
ECM
or
P0608
Vehicle Speed Output Circuit
ECM
DTC P0608
P060D
Control Module Accelerator Pedal Position (APP) System Performance
ECM
DTC P060D for the 6.0L engine
or
DTC P060D for the 7.0L engine
P0615
Starter Relay Control Circuit
ECM
DTC P0615
P0621
Generator L-Terminal Circuit
ECM
DTC P0621
P0622
Generator F-Terminal Circuit
ECM
DTC P0622
P062F
Control Module EEPROM Error
ECM
or
P0634
Transmission Control Module (TCM) Overtemperature
TCM
DTC P0634
P0641
5-Volt Reference 1 Circuit
ECM
DTC P0641 for the 6.0L engine
or
DTC P0641 for the 7.0L engine
P0645
Air Conditioning (A/C) Clutch Relay Control Circuit
ECM
DTC P0645
P0650
Malfunction Indicator Lamp (MIL) Control Circuit
ECM
DTC P0650 for the 6.0L engine
or
DTC P0650 for the 7.0L engine
P0651
5-Volt Reference 2 Circuit
ECM
DTC P0651 for the 6.0L engine
or
DTC P0651 for the 7.0L engine
P0654
Engine Speed Output Circuit
ECM
DTC P0654
P0667
Transmission Control Module (TCM) Temperature Sensor Performance
TCM
DTC P0667, P0668, or P0669
P0668
Transmission Control Module (TCM) Temperature Sensor Circuit Low Voltage
TCM
P0669
Transmission Control Module (TCM) Temperature Sensor Circuit High Voltage
TCM
P0685
Engine Controls Ignition Relay Control Circuit
ECM
DTC P0685, P0689, or P0690 for the 6.0L engine
or
DTC P0685, P0689, or P0690 for the 7.0L engine
P0689
Engine Controls Ignition Relay Feedback Circuit Low Voltage
ECM
or
P0690
Engine Controls Ignition Relay Feedback Circuit High Voltage
ECM
or
P0700
Transmission Control Module (TCM) Requested MIL Illumination
ECM
DTC P0700 for the 6.0L engine
or
DTC P0700 for the 7.0L engine
P0703
Brake Switch 2 Circuit
TCM
DTC P0703
P0711
Transmission Fluid Temperature (TFT) Sensor Performance
TCM
DTC P0711, P0712, or P0713
P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage
ECM, TCM
DTC P0712 for the Tremec 6-Speed transmission
or
DTC P0711, P0712, or P0713 for the 6L80-E transmission
P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage
ECM, TCM
DTC P0713 for the Tremec 6-Speed transmission
or
P0716
Speed Sensor Performance
TCM
DTC P0716 or P0717
P0717
Input Speed Sensor Circuit Low Voltage
TCM
DTC P0716 or P0717
P0719
Brake Switch Circuit Low Voltage
TCM
DTC P0719
P0722
Output Speed Sensor Circuit Low Voltage
TCM
DTC P0722 or P0723
P0723
Output Speed Sensor Circuit Intermittent
TCM
DTC P0722 or P0723
P0724
Brake Switch Circuit High Voltage
TCM
DTC P0724
P0736
Incorrect Reverse Ratio
TCM
DTC P0736
P0741
Torque Converter Clutch (TCC) System - Stuck Off
TCM
DTC P0741 or P0742
P0742
Torque Converter Clutch (TCC) System - Stuck On
TCM
DTC P0741 or P0742
P0751
1-2 Shift Solenoid (SS) Valve Performance - No First or Fourth Gear
TCM
DTC P0751
P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear
TCM
DTC P0752
P0756
2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear
TCM
DTC P0756
P0776
Clutch Pressure Control (PC) Solenoid 2 - Stuck Off
TCM
DTC P0776 or P0777
P0777
Clutch Pressure Control (PC) Solenoid 2 - Stuck On
TCM
DTC P0776 or P0777
P0796
Clutch Pressure Control (PC) Solenoid 3 - Stuck Off
TCM
DTC P0796 or P0797
P0797
Clutch Pressure Control (PC) Solenoid 3 - Stuck On
TCM
DTC P0796 or P0797
P0801
Reverse Inhibit Solenoid Control Circuit
ECM
DTC P0801
P0803
Skip Shift Solenoid Control Circuit
ECM
DTC P0803
P0815
Upshift Switch Circuit
TCM
DTC P0815, P0816, or P0826
P0816
Downshift Switch Circuit
TCM
P0826
Up and Down Shift Switch Circuit
TCM
P0833
Clutch Pedal Switch 2 Circuit
ECM
DTC P0833
P0842
Transmission Fluid Pressure (TFP) Switch 1 Circuit Low Voltage
TCM
DTC P0842 or P0843
P0843
Transmission Fluid Pressure (TFP) Switch 1 Circuit High Voltage
TCM
DTC P0842 or P0843
P0851
Park/Neutral Position (PNP) Switch Circuit Low Voltage
TCM
DTC P0851 or P0852
P0852
Park/Neutral Position (PNP) Switch Circuit High Voltage
TCM
DTC P0851 or P0852
P0872
Transmission Fluid Pressure (TFP) Switch 3 Circuit Low Voltage
TCM
DTC P0872 or P0873
P0873
Transmission Fluid Pressure (TFP) Switch 3 Circuit High Voltage
TCM
DTC P0872 or P0873
P0877
Transmission Fluid Pressure (TFP) Switch 4 Circuit Low Voltage
TCM
DTC P0877 or P0878
P0878
Transmission Fluid Pressure (TFP) Switch 4 Circuit High Voltage
TCM
DTC P0877 or P0878
P0961
Line Pressure Control (PC) Solenoid System Performance
TCM
DTC P0961, P0962 or P0963
P0962
Line Pressure Control (PC) Solenoid Control Circuit Low Voltage
TCM
P0963
Line Pressure Control (PC) Solenoid Control Circuit High Voltage
TCM
P0965
Clutch Pressure Control (PC) Solenoid 2 System Performance
TCM
DTC P0965, P0966 or P0967
P0966
Clutch Pressure Control (PC) Solenoid 2 Control Circuit Low Voltage
TCM
P0967
Clutch Pressure Control (PC) Solenoid 2 Control Circuit High Voltage
TCM
P0969
Clutch Pressure Control (PC) Solenoid 3 System Performance
TCM
DTC P0969, P0970 or P0971
P0970
Clutch Pressure Control (PC) Solenoid 3 Control Circuit Low Voltage
TCM
P0971
Clutch Pressure Control (PC) Solenoid 3 Control Circuit High Voltage
TCM
P0973
1-2 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0973 or P0974
P0974
1-2 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0973 or P0974
P0976
2-3 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0976 or P0977
P0977
2-3 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0976 or P0977
P0989
Transmission Fluid Pressure (TFP) Switch 5 Circuit Low Voltage
TCM
DTC P0989 or P0990
P0990
Transmission Fluid Pressure (TFP) Switch 5 Circuit High Voltage
TCM
DTC P0989 or P0990
P1101
Intake Air Flow System Performance
ECM
DTC P1101 for the 6.0L engine
or
DTC P1101 for the 7.0L engine
P1133
HO2S Insufficient Switching Bank 1 Sensor 1
ECM
DTC P1133 or P1153 for the 6.0L engine
or
DTC P1133 or P1153 for the 7.0L engine
P1134
HO2S Transition Time Ratio Bank 1 Sensor 1
ECM
DTC P1134 or P1154 for the 6.0L engine
or
DTC P1134 or P1154 for the 7.0L engine
P1153
HO2S Insufficient Switching Bank 2 Sensor 1
ECM
or
P1154
HO2S Transition Time Ratio Bank 2 Sensor 1
ECM
or
P1258
Engine Coolant Overtemperature - Protection Mode Active
ECM
DTC P1258
P1380
Misfire Detected - Rough Road Data Not Available
ECM
DTC P1380 for the 6.0L engine
or
DTC P1380 for the 7.0L engine
P1381
Misfire Detected - No Communication With Brake Control Module
ECM
DTC P1381 for the 6.0L engine
or
DTC P1381 for the 7.0L engine
P1482
Cooling Fan Speed Output Circuit
ECM
DTC P1482
P1516
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
ECM
DTC P1516 for the 6.0L engine
or
DTC P1516 for the 7.0L engine
P1617
Engine Oil Level Switch Circuit
ECM
DTC P1617
P1621
Transmission Control Module Long Term Memory Performance
TCM
P1630
Theft Deterrent Learn Mode Active
ECM
DTC P1630
P1631
Theft Deterrent Fuel Enable Signal Not Correct
ECM
DTC P1631
P166A
Exhaust Control Valve Control Circuit
EFCM
DTC P166A
P1682
Ignition 1 Switch Circuit 2
ECM
DTC P1682 for the 6.0L engine
or
DTC P1682 for the 7.0L engine
P1684
Transmission Control Module (TCM) Power Up Temperature Sensor Performance
TCM
DTC P1684, P1685 or P1686
P1685
Transmission Control Module (TCM) Power Up Temperature Sensor Circuit Low Voltage
TCM
P1686
Transmission Control Module (TCM) Power Up Temperature Sensor Circuit High Voltage
TCM
P1751
Shift Valve 1 Performance
TCM
DTC P1751
P1825
Internal Mode Switch - Invalid Range
TCM
DTC P1825 or P1915
P1831
Pressure Control (PC)/Shift Lock Solenoid Control Circuit Low Voltage
TCM
DTC P1831 or P1832
P1832
Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
TCM
DTC P1831 or P1832
P1915
Internal Mode Switch Start/Wrong Range
TCM
DTC P1825 or P1915
P2066
Fuel Level Sensor 2 Performance
ECM
DTC P2066 or P2636
P2067
Fuel Level Sensor 2 Circuit Low Voltage
ECM
DTC P2067
P2068
Fuel Level Sensor 2 Circuit High Voltage
ECM
DTC P2068
P2101
Control Module Throttle Actuator Position Performance
ECM
DTC P2101 for the 6.0L engine
or
DTC P2101 for the 7.0L engine
P2119
Throttle Closed Position Performance
ECM
DTC P2119 for the 6.0L engine
or
DTC P2119 for the 7.0L engine
P2120
Accelerator Pedal Position (APP) Sensor 1 Circuit
ECM
DTC P2120 for the 6.0L engine
or
DTC P2120 for the 7.0L engine
P2122
Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
ECM
DTC P2122 for the 6.0L engine
or
DTC P2122 for the 7.0L engine
P2123
Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
ECM
DTC P2123 for the 6.0L engine
or
DTC P2123 for the 7.0L engine
P2125
Accelerator Pedal Position (APP) Sensor 2 Circuit
ECM
DTC P2125 for the 6.0L engine
or
DTC P2125 for the 7.0L engine
P2127
Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
ECM
DTC P2127 for the 6.0L engine
or
DTC P2127 for the 7.0L engine
P2128
Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
ECM
DTC P2128 for the 6.0L engine
or
DTC P2128 for the 7.0L engine
P2135
Throttle Position (TP) Sensor 1-2 Correlation
ECM
DTC P2135 for the 6.0L engine
or
DTC P2135 for the 7.0L engine
P2138
Accelerator Pedal Position (APP) Sensor 1-2 Correlation
ECM
DTC P2138 for the 6.0L engine
or
DTC P2138 for the 7.0L engine
P2176
Minimum Throttle Position Not Learned
ECM
DTC P2176 for the 6.0L engine
or
DTC P2176 for the 7.0L engine
P2534
Ignition 1 Switch Circuit Low Voltage
TCM
DTC P2534
P2610
Control Module Ignition Off Timer Performance
ECM
or
P2636
Fuel Transfer Pump Flow Insufficient
ECM
DTC P2066 or P2636
P2714
Clutch Pressure Control (PC) Solenoid 4 - Stuck Off
TCM
DTC P2714 or P2715
P2715
Clutch Pressure Control (PC) Solenoid 4 - Stuck On
TCM
DTC P2714 or P2715
P2719
Clutch Pressure Control (PC) Solenoid 4 System Performance
TCM
DTC P2719, P2720 or P2721
P2720
Clutch Pressure Control (PC) Solenoid 4 Control Circuit Low Voltage
TCM
P2721
Clutch Pressure Control (PC) Solenoid 4 Control Circuit High Voltage
TCM
P2723
Clutch Pressure Control (PC) Solenoid 5 - Stuck Off
TCM
DTC P2723 or P2724
P2724
Clutch Pressure Control (PC) Solenoid 5 - Stuck On
TCM
DTC P2723 or P2724
P2728
Clutch Pressure Control (PC) Solenoid 5 System Performance
TCM
DTC P2728, P2729 or P2730
P2729
Clutch Pressure Control (PC) Solenoid 5 Control Circuit Low Voltage
TCM
P2730
Clutch Pressure Control (PC) Solenoid 5 Control Circuit High Voltage
TCM
P2762
Torque Converter Clutch (TCC) Pressure Control Solenoid System Performance
TCM
DTC P2762, DTC P2763 or DTC P2764
P2763
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage
TCM
P2764
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage
TCM
P2A01
HO2S Circuit Bank 1 Sensor 2
ECM
DTC P2A01 or P2A04 for he 6.0L engine
or
DTC P2A01 or P2A04 for the 7.0L engine
P2A04
HO2S Performance Bank 2 Sensor 2
ECM
or
U0001
High Speed CAN Communication Bus
ECM
DTC U0001
U0101
Lost Communications with Transmission Control Module (TCM)
ECM
DTC U0100-U0299
U0121
Lost Communications with Electronic Brake Control Module (EBCM)
ECM
DTC U0100-U0299
U0140
Lost Communication With Body Control Module (BCM)
ECM
DTC U0100-U0299
U1000
Class 2 Data Link
BCM, DDM, DDS, DPM, DRR, FTC, HUD, IPC, PDM, Radio, RCDLR, SCLCM, SDM, VCIM
DTC U1000 and U1255
U1017
Lost Communications with Engine Control Module (ECM)
DDM, DDS, DRR, FTC, HVAC, HUD, IPC, PDM, Radio, RCDLR, SDM, VCIM
DTC U1001-U1254
U1024
DDS, DDM, DPM, FTC, IPC, HUD, PDM, Radio, RCDLR
DTC U1001-U1254
U1040
IPC
DTC U1001-U1254
U1064
Lost Communications with Body Control Module (BCM)
DDM, DDS, DPM, DRR, FTC, HVAC, HUD, IPC, PDM, Radio, RCDLR, SDM, VCIM
DTC U1001-U1254
U1088
Lost Communication with Sensing and Diagnostic Module (SDM)
BCM, IPC
DTC U1001-U1254
U1096
Lost Communication with Instrument Panel Cluster (IPC)
BCM, DDM, HUD, HVAC, PDM, Radio, SDM
DTC U1001-U1254
U1098
Lost Communications with Head Up Display (HUD)
BCM, IPC
DTC U1001-U1254
U1128
Lost Communications with Radio
DRR, IPC, HUD
DTC U1001-U1254
U1137
Lost Communications with Digital Radio Receiver (DRR)
Radio
DTC U1001-U1254
U1151
Lost Communications with Communication Interface Module (OnStar®)
IPC
DTC U1001-U1254
U1153
Lost Communication with HVAC Control Module
BCM, DDM, IPC, HUD, PDM, Radio
DTC U1001-U1254
U1160
Lost Communications with Driver Door Module (DDM)
IPC
DTC U1001-U1254
U1161
Lost Communications with Passenger Door Module (PDM)
IPC
DTC U1001-U1254
U1164
Lost Communications with Driver Door Switch (DDS)
DDM, DPM, DRR, IPC, PDM, Radio, RCDLR
DTC U1001-U1254
U1166
Lost Communication with Driver Position Module (DPM)
IPC
DTC U1001-U1254
U1177
Lost Communications with Folding Top Controller (FTC)
DDM, HVAC, IPC, PDM
DTC U1001-U1254
U1193
Lost Communications with Remote Control Door Lock Receiver (RCDLR)
BCM, DDM, DDS, DPM, DRR, FTC, HVAC, HUD, IPC, PDM, Radio, SDM, VCIM
DTC U1001-U1254
U1194
Lost Communications with Steering Column Lock Control Module (SCLCM)
BCM, IPC
DTC U1001-U1254
U1255
Class 2 Data Link
HVAC
DTC U1000 and U1255
U1300
Class 2 Data Link Low
DDM, DDS, DRR, HVAC, IPC, PDM, Radio, SDM, VCIM
DTC U1300, U1301, or U1305
U1301
Class 2 Data Link High
U1305
Class 2 Data Link Low or High
BCM, DPM, FTC, HUD, SCLCM
U1500
Inter-device Dedicated Bus 1
VCIM
DTC U1500
U2100
Controller Area Network (CAN) Bus Communication
ESC, BCM, EBCM, TCM
DTC U2100
U2105
Lost Communication with Engine Control Module (ECM)
BCM, EBCM, ESC, TCM
DTC U2105-U2199
U2106
Lost Communication With Transmission Control Module (TCM)
BCM, EBCM
DTC U2105-U2199
U2107
EBCM, ESC, TCM
DTC U2105-U2199
U2108
Lost Communication With Electronic Brake Control Module (EBCM)
BCM, ESC, TCM
DTC U2105-U2199
U2112
Lost Communications With Electronic Suspension Control Module (ESC)
EBCM
DTC U2105-U2199
U2153
Navigation Electronic Control Unit (ECU) - VICS Communication Circuit
Navigation Radio
DTC U2153
023
Seat Belt Tension Sensor Circuit Out of Range
PPS
DTC 023
024
PPS Ignition 1 Voltage Performance
PPS
DTC 024
063
PPS Out of Calibration
PPS
DTC 063
064
PPS Communication/ID Performance
PPS
DTC 064
065
PPS Sensor Circuit Out of Range
PPS
DTC 065
