Use the following information and Service Tips to assist in the diagnosis of HO2S, Catalyst, and Fuel System Monitor related DTCs.
A.) Description of Terms and Acronyms
CHT - Cylinder Head Temperature Sensor or PID
CKP - Crankshaft Position Sensor or PID
DTC - Diagnostic Trouble Code
ECT - Engine Coolant Temperature Sensor or PID
EGR - Exhaust Gas Recirculation
EEC - Electronic Engine Control
EVR - EGR Vacuum Regulator
FMEM - Failure Mode Effects Management
GND - Ground
HC - Hydrocarbons
HO2S - Heated Oxygen Sensor or PID
IAT - Inlet Air Temperature Sensor or PID
KAM - Keep Alive Memory
KOEO - Key On Engine Off
KOER - Key On Engine Running
LONGFT - Long Term Fuel Trim
MAF - Mass Air Flow Sensor or PID
MIL - Malfunction Indicator Lamp ("Check Engine")
NGS - New Generation Star Tester (Scan Tool)
OBD II - On-Board Diagnostics II
OSM - Output State Monitor
PC/ED - Powertrain Control/Emissions Diagnosis
PCM - Powertrain Control Module
PCV - Positive Crankcase Ventilation
PID - Parameter Identification Display
RAM - Random Access Memory
RPM - Revolutions Per Minute
SHRTFT - Short Term Fuel Trim
Stoichiometric - 14.7:1 Air/Fuel Ratio (Gasoline Engines)
TP - Throttle Position Sensor or PID
VMV - Vapor Management Valve
VPWR - Vehicle Power (Battery Voltage)
VREF - Vehicle Reference Voltage (5 volts)
C1.) Heated Oxygen Sensor (HO2S) Monitor - Information
The HO2S Monitor is an on-board strategy designed to monitor the HO2S sensors for a malfunction or deterioration that can affect emissions. Under specific conditions, the fuel control or upstream HO2S sensors are checked for proper output voltage and response rate (the time it takes to switch from lean to rich or rich to lean
Downstream HO2S sensors used for Catalyst Monitor are also monitored for proper output voltage. Input is required from the ECT or CHT, IAT, MAF, TP and CKP sensors to activate the HO2S Monitor.
The Fuel System Monitor and Misfire Detection Monitor must also have completed successfully before the HO2S Monitor is enabled.
The HO2S sensor senses the oxygen content in the exhaust flow and outputs a voltage between zero and 1.0 volt. Lean of stoichiometric (air/fuel ratio of approximately 14.7:1 for gasoline engines), the HO2S will generate a voltage between zero and 0.45 volt.
Rich of stoichiometric, the HO2S will generate a voltage between 0.45 and 1.0 volt.
The HO2S Monitor evaluates both the upstream (Fuel Control) and downstream (Catalyst Monitor) HO2S for proper function.
Once the HO2S Monitor is enabled, the upstream HO2S signal voltage amplitude and response frequency are checked. Excessive voltage is determined by comparing the HO2S signal voltage to a maximum calibratable threshold voltage.
A fixed frequency closed loop fuel control routine is executed and the upstream HO2S voltage amplitude and output response frequency are observed. A sample of the upstream HO2S signal is evaluated to determine if the sensor is capable of switching or has a slow response rate.
An HO2S heater circuit fault is determined by turning the heater on and off and looking for a corresponding change in the OSM and by measuring the current going through the heater circuit.
The MIL is activated after a fault is detected on two consecutive OBD II drive cycles.
The HO2S Monitor DTCs can be categorized as follows:
HO2S signal circuit malfunction - P0131, P0136, P0151, P0156
HO2S slow response rate - P0133, P0153
HO2S heater circuit malfunction - P0135, P0141, P0155, P0161
Downstream HO2S not running in on-demand self test - P1127
Swapped HO2S connectors - P1128 and P1129
HO2S lack of switching - P1130, P1131, P1132, P1150, P1151, P1152
HO2S lack of switching (sensor indicates lean) - P1137
HO2S lack of switching (sensor indicates rich) - P1138
Catalyst Efficiency Monitor - Information
The Federal Test Procedure Catalyst Monitor monitors for deterioration in the catalyst system and illuminates the MIL when tailpipe emissions exceed the appropriate HC emission thresholds. The Catalyst
Monitor is enabled after the upstream and downstream HO2S sensors have been tested and verified to be functional. This monitor relies on the front and rear heated oxygen sensors (HO2S) to infer catalyst efficiency based upon oxygen storage capacity.
Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage which makes the switching frequency of the rear HO2S quite slow compared with the frequency of the front HO2S.
As catalyst efficiency deteriorates, its ability to store oxygen declines, and the rear HO2S begins to switch more rapidly, approaching the frequency of the front sensor.
In general, as catalyst efficiency decreases, the switch ratio increases from a switch ratio of 0 for a low mileage catalyst to a switch ratio of 0.8 or 0.9 for a low efficiency catalyst.
Some vehicles will monitor substantially less than the entire catalyst volume in order to meet the stringent catalyst monitoring malfunction thresholds. In many cases, only the front, light-off catalyst is monitored.
Front and rear HO2S switches are counted under specified closed loop fuel conditions. After the required number of front switches are obtained, a rear-to-front HO2S switch ratio is calculated.
The switch ratio is compared against a threshold value. If the switch ratio is greater than the calibrated maximum limit, the catalyst has failed.
The test entry conditions for the Catalyst Efficiency Monitor are as follows: ECT or CHT (warmed engine), IAT (not at extreme ambient temperatures), MAF (greater than minimum engine load), VSS (within vehicle speed window) and TP (at part throttle) are required.
Because an exponentially weighted moving average is used for malfunction determination, up to six OBD II drive cycles may be required to illuminate the MIL.
NOTE: THE CATALYST MONITOR ON SOME EARLY OBD II VEHICLES (SOME 1994-1996 VEHICLES) WAS REFERRED TO AS THE "STEADY-STATE CATALYST MONITOR" AS OPPOSED TO THE "FTP CATALYST MONITOR" (DESCRIBED ABOVE) THAT IS MOST COMMON FOR VEHICLES BUILT AFTER 1996. BELOW IS A BRIEF DESCRIPTION OF THE STEADY-STATE CATALYST MONITOR:
The Steady-State Catalyst Monitor performs a 20 second test during steady state rpm and load conditions. The Monitor transfers closed loop fuel control from the front to the rear O2 sensors.
The Monitor then observes the switching frequency and compares it to a threshold frequency stored in an rpm/load table. A frequency higher than the maximum calibrated threshold indicates a malfunction.
The Catalyst Monitor DTCs can be categorized as follows:
Catalyst system efficiency below threshold (Bank 1) - P0420
Catalyst system efficiency below threshold (Bank 2) - P0430
Fuel System Monitor - Information
The Fuel System Monitor is an on-board strategy designed to monitor the fuel trim system. The fuel control system uses fuel trim tables stored in the PCM's KAM to compensate for variability in fuel system components due to normal wear and aging.
Fuel trim tables are based on vehicle speed and engine load. During closed loop vehicle operation, the fuel trim strategy learns the corrections needed to correct a "biased" rich or lean fuel system.
The correction is stored in the fuel trim tables. The fuel trim has two means of adapting; a LONGFT and a SHRTFT. LONGFT relies on the fuel trim tables and SHRTFT refers to the desired air/fuel ratio parameter "LAMBSE". LAMBSE is calculated by the PCM from HO2S inputs and helps maintain a 14.7:1 air/fuel ratio during closed loop operation.
SHRTFT and LONGFT work together. If the HO2S indicates the engine is running rich, the PCM will correct the rich condition by moving SHRTFT in the negative range (less fuel to correct for a rich combustion).
If after a certain amount of time SHRTFT is still compensating for a rich condition, the PCM "learns" this and moves LONGFT into the negative range to compensate and allows SHRTFT to return to a value near 0%.
Input from the ECT or CHT, IAT, and MAF sensors is required to activate the fuel trim system, which in turn activates the Fuel System Monitor. Once activated, the Fuel System Monitor looks for the fuel trim tables to reach the adaptive clip (adaptive limit) and LAMBSE to exceed a calibrated limit.
The Fuel System Monitor will store the appropriate DTC when a fault is detected as described below.
The HO2S detects the presence of oxygen in the exhaust and provides the PCM with feedback indicating a rich or lean condition.
A correction factor is added to the fuel injector pulsewidth calculation according to the Long and Short Term Fuel Trims as needed to compensate for variations in the fuel system.
When deviation in the parameter LAMBSE increases, air/fuel control suffers and emissions increase. When LAMBSE exceeds a calibrated limit and the fuel trim table has clipped (reached adaptive limit), the Fuel System Monitor sets a DTC.
The Fuel System Monitor DTCs can be categorized as follows:
Fuel Delivery Error - P0148
Lean shift in fuel system operation - P0171 (Bank 1) and P0174 (Bank 2)
Rich shift in fuel system operation - P0172 (Bank 1) and P0175 (Bank 2)
Diagnostic Service Tips - General
Always reset KAM after performing a repair: After performing a repair on a vehicle with the MIL on, and/or DTCs present, always clear KAM.
When a malfunction is present, the PCM adapts (attempts to correct) for this condition.
Once the vehicle has been repaired, if the KAM is not reset, the PCM will once again have to adapt back to the normal operating conditions.
Clearing the KAM will erase what the PCM has learned, so the PCM will be able to start with "base tables".
Always view and record Freeze Frame Data: Freeze Frame Data can be a valuable asset in duplicating and diagnosing concerns.
This data (a snapshot of certain PID values, recorded at the time the MIL was activated) indicates the manner in which the vehicle was being driven at the time the fault occurred. This can be especially useful on intermittent concerns.
Freeze Frame Data, in some cases, can also help to isolate possible areas of concern, as well as ruling out others. Always record (write down) the Freeze Frame Data.
Multiple DTCs (with the same meaning): When multiple (paired) DTCs with the same meaning are set for multiple sensors, it is unlikely that replacing both HO2S sensors will resolve the concern. In most cases, there will be another issue that is causing the codes.
Examples of multiple (paired) DTCs: (P0135/P0155), (P0141/P0161), (P1131/P1151), (P1132/P1152).
To further clarify this, see the more detailed scenario as follows:
A vehicle comes in with a MIL On concern. KOEO self test reveals DTCs P0135 and P0155 (HTR-11 and HTR-21 circuit malfunction), with no other DTCs present.
The most likely cause of these DTCs would be something in the heater power circuit that both of these HO2S sensors have in common (Example: open or shorted heater circuit wiring or splice).
It is highly unlikely that multiple sensors would fail at the same time. When multiple DTCs of this nature are encountered, reviewing the appropriate wiring diagram(s) can help to isolate possible areas of concern. When reviewing the wiring diagram, look for things that the affected sensors have in common.
In this example, the most likely cause of DTCs P0135 and P0155 (with no other DTCs present) would be a concern with Splice "B"
View HO2S PID data carefully: NGS PIDs for HO2S sensors that do not exist (with certain exhaust configurations) will show a value of "0" volts
In this example, the vehicle (equipped with a 4-cylinder engine) has one upstream and one downstream HO2S. Notice that the NGS (scan tool) display shows two upstream and two downstream HO2S PIDs, and that the "unused" HO2S sensor PIDs display "0" volts.
HO2S sensors measure oxygen in the exhaust, not fuel: The exhaust gas condition reported by the HO2S sensor is based on the presence of oxygen in the exhaust, not the presence of unburned fuel.
Example:
In the event of an ignition-related misfire, you might expect a rich HO2S reading, due to the amount of unburned fuel in the exhaust system. However, there is also a large amount of unburned oxygen, since no combustion took place in the misfiring cylinder. Since the HO2S senses oxygen only, it would report a lean condition in this particular situation.
Tips Related to Heated Oxygen Sensor (HO2S) Monitor
OBD II Response Rate Monitor: The OBD II Response Rate Monitor (P0133/P0153) is only run at vehicle speeds between approximately 50-95 km/h (30-60 mph), during steady-state conditions.
The test lasts approximately 6 seconds. Therefore, P0133/P0153 cannot be diagnosed at idle in the repair bay.
Do not compare HO2S switch rate - Bank-to-Bank or vehicle-to-vehicle: Different HO2S switch rates, from Bank-to-Bank, are considered normal.
The HO2S switch rate, from one Bank to the other, should not be compared as a gauge of the HO2S's ability to switch/react. The PCM is continuously adjusting spark and fuel in reaction to engine operating conditions (rpm, load, air flow, throttle angle, etc.). The PCM is also continuously adapting to certain conditions (customer driving habits, engine and component wear, etc.).
Tips Related to Catalyst Efficiency Monitor
Determining catalyst efficiency/switch ratio: The upstream HO2S sensors will have a high switch frequency, due to normal closed loop fuel control. With an efficient catalyst, the downstream HO2S will have a low switch frequency.
The switch ratio is determined by dividing the number of downstream switches by the number of upstream switches over a given period of time. As the catalyst ages (or if the catalyst is damaged or contaminated), the downstream switches will increase.
When the downstream switch rate crosses a threshold value (approximately 0.75 switch ratio), a code is stored (P0420 and/or P0430) and the MIL illuminates (refer to Figure 5 and Figure 6 ).
NOTE: IF A CATALYST IS DETERMINED TO HAVE LOW EFFICIENCY AND REQUIRES REPLACEMENT, REPLACEMENT OF THE DOWNSTREAM HO2S SENSORS WILL NOT BE NECESSARY.
Use care in handling HO2S sensors: In the event of catalyst replacement, use care in the handling of HO2S sensors to prevent damage or contamination.
Do not use power tools in the removal or installation of sensors. Use a 22mm wrench or crow foot to remove and install HO2S sensors; do not use slotted sockets, as these sockets may damage wires. HO2S sensors should be torqued to 41 ±5 N-m (30 ±4 lb-ft).
Do not replace downstream HO2S sensors (HO2S12/HO2S22) for DTCs P0420 and/or P0430: When diagnosing a vehicle with a customer concern of MIL On and DTCs P0420/P0430 in continuous memory, do not replace the downstream HO2S sensors (HO2S12/HO2S22).
Damaged or malfunctioning downstream HO2S sensors will not cause these DTCs to be set. Always verify the vehicle concern, then perform the pinpoint diagnostics in the appropriate PC/ED Service Manual.
Tips Related to the Fuel System Monitor
HO2S sensors are not likely to be the cause of adaptive DTCs P0171, P0172, P0174, P0175: Most warranty-returned HO2S sensors (replaced for these DTCs) are found to function normally. Additional related DTCs will normally be present if there is a concern with the HO2S sensors.
Do not replace an HO2S sensor unless verified through pinpoint diagnostic tests found in the PC/ED Service Manual.
DTCs P0171, P0172, P0174, and P0175 are not related to downstream HO2S sensors: When diagnosing a vehicle with a MIL On and DTC(s) P0171, P0172, P0174, and/or P0175 in continuous memory, do not replace the downstream HO2S sensors.
These DTCs have no connection to the downstream HO2S sensor function nor its diagnosis for faults. Always verify the vehicle concern, then perform the pinpoint diagnostics from the appropriate PC/ED Service Manual.
Diagnosing lean conditions and lean DTCs P0171, P0174: Freeze Frame Data can often help to identify the type of lean condition, even if the fault is intermittent, by indicating how the vehicle was being driven when the fault occurred.
Diagnosis of lean conditions and lean adaptive DTCs can be difficult, especially if the concern is intermittent. Verifying the concern is extremely important. There are different types of lean conditions.
The ability to identify the type of lean condition causing the concern can be crucial to a correct diagnosis. When DTCs P0171 and P0174 are both present, there is a strong likelihood of another concern being present:
Vacuum leaks/unmetered air: In this type of condition, the engine may actually run lean of stoichiometry (14.7:1 air/fuel ratio) if the PCM is not able to compensate enough to correct for the condition.
This condition is typically caused by air entering the engine through an abnormal source (opening), or due to a MAF malfunction. In this situation, the volume of air entering the engine is actually greater than what the MAF is indicating to the PCM. Vacuum leaks will normally be most apparent when high manifold vacuum is present, during idle or light throttle.
If Freeze Frame Data indicates that the fault occurred at idle, a check for vacuum leaks/unmetered air when the engine is cold might be the best starting point.
Examples: Loose, leaking or disconnected vacuum lines, intake manifold gaskets or O-rings, throttle body gaskets, brake booster, air inlet tube, stuck/frozen/aftermarket PCV valve, unseated engine oil dipstick, MAF reading lower than normal, etc.
Insufficient fueling: In this type of condition, the engine may actually run lean of stoichiometry (14.7:1 air/fuel ratio) if the PCM is not able to compensate enough to correct for the condition.
This condition is typically caused by a fuel delivery system concern that restricts or limits the amount of fuel being delivered to the engine. This condition will normally be most apparent when the engine is under a heavy load, when a higher volume of fuel is required.
If Freeze Frame Data indicates that the fault occurred under a heavy load, a check of the fuel delivery system (checking fuel pressure with engine under a load) might be the best starting point.
Examples: Low fuel pressure (fuel pump, fuel filter, fuel leaks, restricted fuel supply lines), fuel injector concerns, etc.
Exhaust system leaks: In this type of condition, the engine may actually be running near stoichiometry (14.7:1 air/fuel ratio), but the exhaust gas mixture will be lean.
This condition is caused by oxygen-rich air entering the exhaust system through an external source. This condition will cause the exhaust gas mixture to be lean, even though the actual combustion in the engine may not be.
Examples: Exhaust system leaks upstream or near HO2S, malfunctioning Secondary Air Injection system.
MAF concerns:
Checking fuel pressure: Check fuel pressure with engine under a load when diagnosing a lean concern. A partially plugged fuel filter can be difficult to detect and can be easily overlooked if fuel pressure is only checked at idle.
The same is true for other types of fuel supply concerns (e.g., bent or kinked lines, degraded fuel pump).
At idle, an engine requires only a small volume of fuel. Due to the fact that there is a small volume of fuel needed at idle, a restriction in the fuel supply line in many cases will not cause the fuel pressure to be low.
When the vehicle is under a load, the engine requires much more fuel than at idle. Under a load, a restriction in the fuel supply line will prevent the high rate of fuel flow that is needed to maintain the correct fuel pressure.
