Fastener Tightening Specifications
Application
Specifications
Metric
English
Accelerator Pedal Position (APP) Assembly Bolts
20 N·m
15 lb ft
AIR Check Valves
23 N·m
17 lb ft
AIR Pipe To Exhaust Manifold Bolts
20 N·m
15 lb ft
AIR Right Side Pipe Bracket-to-Cylinder Head Bolt
25 N·m
18 lb ft
AIR Pump to Bracket
9 N·m
80 lb in
Camshaft Position (CMP) Sensor Bolt
25 N·m
18 lb ft
Crankshaft Position (CKP) Sensor Bolt
25 N·m
18 lb ft
Engine Coolant Temperature (ECT) Sensor
17 N·m
13 lb ft
Fuel Crossover Hose Clamps (3 Inch Diameter)
4 N·m
35 lb in
Fuel Filter/Fuel Pressure Regulator Bracket Nut
4.5 N·m
40 lb in
Fuel Pipe Assembly Clip Nuts
3 N·m
27 lb in
Fuel Rail Attaching Bolts
10 N·m
89 lb in
Fuel Tank Fill and Vent Pipe Bolts
2.5 N·m
22 lb in
Fuel Tank Fill Hose Clamp
4 N·m
35 lb in
Fuel Tank Fill Pipe Ground Strap Bolt
8 N·m
71 lb in
Fuel Tank Strap/Shield Bolts
25 N·m
18 lb ft
Fuel Tank Vent Hose Clamp
4 N·m
35 lb in
Heated Oxygen Sensor (HO2S)
41 N·m
30 lb ft
Knock Sensor (KS)
15 N·m
11 lb ft
Powertrain Control Module (PCM) Electrical Connector Fasteners
8 N·m
70 lb in
PCV Hose Assembly Mounting Cable Nut
12 N·m
106 lb in
Throttle Actuator Control (TAC) Module to PCM Bracket
1.9 N·m
17 lb in
Throttle Body Attaching Bolts
12 N·m
106 lb in
Throttle Position (TP) Sensor Attaching Screws
2 N·m
18 lb in
