Topics3,715
Posts6,904
#1530 - 08/28/02 10:09 AM Live monitor both front 02s
Many times people want to monitor the AFR but want something compact, a standalone meter.
In doing research on AFR meters I found that these meters only monitored 1 02 and were not very accurate.
I decided if I had such a meter what else would I want it to include so I designed a dual 02 AFR meter.
It attaches to 2 02s output wires and via a slider switch will report via 20 LEDs using 3 colors to 1 of the 02s, slide switch to position 2 and see other 02's values or slide to position 3 and it averages both 02s output and displays that on the LED bar.
Also made sure outpput of 02s were clean and any noise was weeded out so LEDs report accurate values.
Here is what it looks like :
This way the user can check to see if both front 02s are reporting the same, if one has gotten lazy or 1 head leaner/richer then the other and have the meter average both sides and report the AFR average.
Size of PCB is 2 1/8 X 3 inches.
#1531 - 06/17/03 12:09 PM Re: Live monitor both front 02s
So is this device for sale or can you list the parts and what is needed in order to build one, alon with schematics. I've seen several kits out there that record 02's, but this device looks handy and inexpensive enuff to build. Seems like it would come in handy.
thanks,
allen
#1532 - 06/18/03 09:51 AM Re: Live monitor both front 02s
I sell a completed unit. It is the only 2 O2s AFR I know of that also averages both O2s on the display or one or the other O2.
1 registered members (teamzr1), 45 guests, and 7 spiders.
