Topics3,715
Posts6,904
#1561 - 07/09/02 10:00 AM STAT SHAFT c5
I WOULD LIKE TO MAKE A THERM SHIM BEFORE I REMOVE THE THERMOSTAT. Does anyone know the diameter of the shaft.
#1562 - 07/09/02 01:32 PM Re: STAT SHAFT c5
Have you read the other writeup I did on team website at : Installing the mod
If you do not want to make shims, use small washers or some even have used the head cut off a screw.
About 3/16 diameter
#1563 - 07/09/02 02:08 PM Re: STAT SHAFT c5
tnanks, this is little known info.
1 registered members (teamzr1), 15 guests, and 9 spiders.
