STAT SHAFT c5
by teamzr1. 11/26/25 11:00 AM
by teamzr1. 12/19/25 10:42 AM
07/09/02
10:00 AM
STAT SHAFT c5
I WOULD LIKE TO MAKE A THERM SHIM BEFORE I REMOVE THE THERMOSTAT. Does anyone know the diameter of the shaft.
07/09/02
01:32 PM
Re: STAT SHAFT c5
Have you read the other writeup I did on team website at :
Installing the mod
If you do not want to make shims, use small washers or some even have used the head cut off a screw.
About 3/16 diameter
07/09/02
02:08 PM
Re: STAT SHAFT c5
tnanks, this is little known info.
), 7 guests, and 6 spiders.
49,470
47,750
45,227
41,347
36,740
32,471
26,284
25,028
