by teamzr1. 09/14/25 03:01 PM
FIA WEC COTA 9/7/25
by teamzr1. 09/08/25 10:10 AM
by teamzr1. 09/07/25 06:30 PM
by teamzr1. 09/07/25 01:49 PM
8/23/25 IMSA at VIR Race
by teamzr1. 09/03/25 07:49 PM
by teamzr1. 09/16/25 03:10 PM
2020 C8 C05B0 DTC Brake TSB
by teamzr1. 09/05/25 05:19 PM
by teamzr1. 09/04/25 01:08 PM
by teamzr1. 09/03/25 02:56 PM
by teamzr1. 09/04/25 07:35 PM
Topics3,653
Posts6,804
#1561 - 07/09/02 11:00 AM STAT SHAFT c5
I WOULD LIKE TO MAKE A THERM SHIM BEFORE I REMOVE THE THERMOSTAT. Does anyone know the diameter of the shaft.
#1562 - 07/09/02 02:32 PM Re: STAT SHAFT c5
Have you read the other writeup I did on team website at : Installing the mod
If you do not want to make shims, use small washers or some even have used the head cut off a screw.
About 3/16 diameter
#1563 - 07/09/02 03:08 PM Re: STAT SHAFT c5
tnanks, this is little known info.
0 registered members (), 17 guests, and 11 spiders.
by teamzr1. 09/16/25 02:30 PM
by teamzr1. 09/13/25 08:20 PM
by teamzr1. 09/09/25 04:29 PM
by teamzr1. 09/06/25 02:59 PM
