A few people have asked about the O2 sensors and wide open throttle operation...so here's the facts on the OPEN/CLOSED Loop operation :
There are 7 different modes (conditions) that are used (besides Key-ON and Key-Off mode) and here's the list of what sensors are monitors and determine the mode:
(1) Engine Start-Up Mode (OPEN LOOP)
Battery Voltage
Coolant Temp
Crank Position
Intake Air Temp
MAP
MAF
TPS
Starter Motor Relay
Cam Position
(2) Engine Warm-Up Mode (OPEN LOOP)
Battery Voltage
Coolant Temp
Crank Position
Intake Air Temp
MAP
MAF
TPS
Cam Position
Park/Neutral Safety Switch (Automatics Only)
(3) Idle mode (Once at Operating Temp: CLOSED LOOP)
A/C Select (if equipped)
A/C Request (if equipped)
Battery Voltage
Coolant Temp
Crank Position
Intake Air Temp
MAP
MAF
TPS
Cam Position
O2 Sensors
(4) Cruise Mode (CLOSED LOOP)
Battery Voltage
Coolant Temp
Crank Position
Intake Air Temp
MAP
MAF
TPS
Cam Position
O2 Sensors
(5) Acceleration Mode (OPEN LOOP)
Battery Voltage
Coolant Temp
Crank Position
Intake Air Temp
MAP
MAF
TPS
Cam Position
Vehicle Speed Sensor
(6) Deceleration Mode (OPEN LOOP)
Battery Voltage
Coolant Temp
Crank Position
Intake Air Temp
MAP
MAF
TPS
Cam Position
(7) Wide Open Throttle - WOT (OPEN LOOP)
Battery Voltage
Coolant Temp
Crank Position
Intake Air Temp
MAP
MAF
TPS
Cam Position
Under conditions 1,2,4,5,6,7...
the O2 Sensor is ignored by the PCM.
