#1616 - 03/21/02 05:31 PM Factory tach
Team, Why does the factory tach, not seem to be able to keep up with the engine rpm's??.
A lot of LS6 owners are having this anomaly........
The rev limiter is bouncing BEFORE the tach needle get's to the redline???. confused
#1617 - 03/21/02 07:34 PM Re: Factory tach
Consider the PCM computer only operates at less then 17 Mhz and your P/C is 200 Mhz to 1 Ghz and now you know why.
With that slow of a CPU at higher loads and RPMs the PCM cannot handle all the functions and monitoring thus the RPMS is considered less of a importance and is not updated as quickly as other functions needed for the engine to operate.
If your into shifting close to the limits then install a shift light, use one that uses LEDs since they will light faster then one that uses a bulb and set it to come on a few hundred RPMs lower then rev limiter, thus when it does come on you will be close to the true limiter RPM.
#1618 - 03/22/02 05:43 PM Re: Factory tach
team, thanks.......many a guy has been asking this question, and no one gave or knew the answer score 1 for you!!!!!! laugh
