by teamzr1. 10/27/25 01:57 PM
by teamzr1. 10/18/25 06:42 PM
by teamzr1. 10/18/25 06:37 PM
by teamzr1. 10/15/25 04:09 PM
by teamzr1. 10/14/25 01:04 PM
by teamzr1. 10/12/25 11:15 AM
by teamzr1. 10/07/25 02:11 PM
by teamzr1. 09/30/25 04:36 PM
WEC Six Hours of Fuji
by teamzr1. 09/29/25 06:24 PM
by teamzr1. 10/27/25 06:32 PM
2025 C8 Production Stats
by teamzr1. 10/22/25 06:29 PM
by teamzr1. 10/21/25 03:12 PM
by teamzr1. 10/09/25 04:29 PM
Test Crashing 2024 & 25 C8s
by teamzr1. 10/08/25 10:55 AM
by teamzr1. 10/27/25 02:47 PM
Topics3,678
Posts6,858
#1616 - 03/21/02 06:31 PM Factory tach
Team, Why does the factory tach, not seem to be able to keep up with the engine rpm's??.
A lot of LS6 owners are having this anomaly........
The rev limiter is bouncing BEFORE the tach needle get's to the redline???. confused
#1617 - 03/21/02 08:34 PM Re: Factory tach
Consider the PCM computer only operates at less then 17 Mhz and your P/C is 200 Mhz to 1 Ghz and now you know why.
With that slow of a CPU at higher loads and RPMs the PCM cannot handle all the functions and monitoring thus the RPMS is considered less of a importance and is not updated as quickly as other functions needed for the engine to operate.
If your into shifting close to the limits then install a shift light, use one that uses LEDs since they will light faster then one that uses a bulb and set it to come on a few hundred RPMs lower then rev limiter, thus when it does come on you will be close to the true limiter RPM.
#1618 - 03/22/02 06:43 PM Re: Factory tach
team, thanks.......many a guy has been asking this question, and no one gave or knew the answer score 1 for you!!!!!! laugh
1 registered members (teamzr1), 9 guests, and 5 spiders.
C4 Production Numbers & RPOs
by teamzr1. 10/27/25 03:00 PM
C3 Production Numbers & RPOs
by teamzr1. 10/27/25 02:53 PM
