Some hate the cags function that forces you into 4th gear from 1st gear.
You could go out and spend about 25 bucks for some vendor selling a disconnect or an easy fix is just go buy a 2.2K 1/2 watt resister (like at radio shack).
Unplug the connector in the trannie and insert the leads of resister into the female pins of cable. This will fool the PCM into thinking the circuit is still active and not trip a PCM error code.
Tape up the ends of both connectors and tie wrap end of cable to something to keep it from dangling.
[ 05-09-2001: Message edited by: teamzr1 ]
