Here is a minivac that I modified to allow getting pressure into the system to allow for a better draining of fluids under pressure
This allows a valve installed inline to be closed, then can pump up the pressure in the minivac bottle to pressure you want and then when valve is opened the fluids are sucked out without getting air into the fluid lines
