Yes that POS is installed but its mostly useless
1. at idle there is not going to be anything but the hot air from the radiators.
2. being heat raises at low speeds or traffic in front of front end the aircleaner still would be sucking in the hot engine air and why as reported the IAT was 140 deg !
3. when car is moving and being airflow is not going to be freely moving ( if it did car would have lots of front end lift) but being aircleaner is not capped off it will still be getting hot engine air and why our Icebox isolates the filter from engine bay and only air it gets then is from outside.
Review my other thread on this as clealry it took minutes once car was movng to go from 140 to 80ish deg temps whereas with the Icebox any speed over 15 MPH and IAT drops to whatever outside temp is.
4. that piece will redirect the air from flowing through radiator and could cause turbulance.
