Rear Suspension Description and Operation
The rear suspension uses a single lightweight fiberglass transverse spring mounted to the crossmember and lower control arms. The following lightweight aluminum components are used throughout the rear suspension:
Rear suspension knuckles
Upper control arms
Lower control arms
Rear suspension toe links
Crossmember
Drive shaft support tube
The shock absorbers attach at the upper end to the frame and at the lower end, to the lower control arm. Shock absorbers help keep the wheels in contact with the road surface under most road conditions. Shock absorbers reduce crash-through at full jounce and rebound.
The electronically controlled shock absorbers are gas charged to reduce aeration (foaming) of the shock fluid. Aeration of the shock fluid results in poor damping control.
